1967 Tempest stock rearend 3.23 gears. Good rearend? - Pontiac GTO Forum
post #1 of 2 (permalink) Old 06-26-2018, 11:43 PM Thread Starter
Hi people on GTO forum, I'm new to this website but it looks like a really good resource. I have a 67 tempest that i am turning into a goat, and it has the stock 10 bolt 3.23 ratio rearend. I was wondering if these are strong enough to hold a good amount of power, or if there is a good posi conversion out there for it? Or should i just upgrade to a 12 bolt or something? I will be putting a 400 with #62 heads and a muncie 4 speed in front of it, so i want a rearend i know can handle it. Thanks
Bumperbrady is offline
post #2 of 2 (permalink) Old 06-27-2018, 07:13 AM
Quoted: 71 Post(s)
If your budget will allow, I'd go with the 12-bolt.
But, some 8.2's will last, with hard street tires.
The only 8.2 I broke was at the track, with slicks, behind a 455.
pinion head is the rear end guy here. He can tell you everything you need to know about rear ends.
bigD is online now
Stock 3.46 gears vs 3.90 gears 6 M trans torrid red sap Drive train, suspension, alignment and brakes. 4 03-27-2015 06:58 PM
1967 gto conv rearend gears 3.23 hall85296 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 04-30-2014 07:48 PM
3:23:1 gears ppurfield001 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 29 12-17-2008 04:51 PM
