1968 GTO Transmission fluid - Pontiac GTO Forum
post #1 of 4 (permalink) Old 08-28-2018, 09:25 AM Thread Starter
Quoted: 20 Post(s)
Hello All It's Bob again...
I got a HT 400 Trans in my 68 GTO. It's showing like 4 inches over the full mark Is this not GOOD???? Should I suck some out to the Full Mark.
Really worried about it????
Tks, Bob
rob40999 is offline
post #2 of 4 (permalink) Old 08-28-2018, 09:59 AM
Quoted: 106 Post(s)
Yes you should.
You posted in the 2004-2006 GTO section, I moved your post to the proper page.
Goat Roper is offline
post #3 of 4 (permalink) Old 08-28-2018, 11:28 AM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
whohh !!
a few questions first
does the dip stick and tube look original ?
its not a chrome after market is it ?
the tip of your stick has a fat end riveted to it correct ?
your checking it running and warm right ?
is the fluid red ?
Scott
a few questions
BLK69JUDGE is offline
post #4 of 4 (permalink) Old 08-29-2018, 06:42 PM Thread Starter
Quoted: 20 Post(s)
1968 gto transmission
Hello Judge: My dip stick does have a round bottom riveited to a flat read the level area. First words are, ADD 1 Pint. Looks like the original??
Yes, taking the reading when Hot, and the Fluid is bright Red.
Good Questions to make sure I got the right dip stick. I just bought the car, and got no paper work with it. The old owner Died....
Guess I should suck some fluid out.
Tks for the help, Bob :-)
rob40999 is offline
GTO transmission fluid 66 GTO 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 05-03-2016 11:58 AM
1965 GTO Manual Transmission fluid change Dave389 Gtoforum.com Site Help 0 05-03-2016 11:32 AM
Transmission Fluid Amount. New conflicting information. 06goatm6 Service, Maintenance and Technical Discussion 1 02-12-2009 10:56 PM
Changing transmission and diff fluid - What tools do I need? 04m6_ca Service, Maintenance and Technical Discussion 1 09-29-2005 10:20 AM
