1972 gto radiator support - Pontiac GTO Forum
post #1 of 4 (permalink) Old 10-25-2016, 07:56 PM Thread Starter
Hi,
I recently bought a 1972 got, and it needs a new radiator core support. I can not seem to find one online at any restoration parts websites. some sites recommend the ventura radiator core support. Can anyone advise me what to do/buy?
Thank you.
cdedic is offline
post #2 of 4 (permalink) Old 10-25-2016, 09:31 PM
Welcome to the board. The V8 '71 & '72 core supports are not reproduced. Ventura II would be very similar to a '68-72 Nova core support, totally different.
On the endura core support in your '72, is it ate up with rust down below the battery & in the lower channel bushing areas? Those are the typical problem spots. Has the core support suffered from a previous wreck where the top panel has been damaged & then pulled out? Have performed metal work & restored many '70, 71, & 72 Pontiac A-body core supports, with a little detail can advise best remedy.
post #3 of 4 (permalink) Old 11-03-2016, 09:21 PM Thread Starter
Hi thanks for the reply, It is currently in the shop, I m going there this Saturday, I will look it over and take some pictures. Also, there is currently a 72 lemans radiator for sale near me locally, would this be a better fit? or is it identical?
Thanks.
cdedic is offline
post #4 of 4 (permalink) Old 11-13-2016, 10:07 PM Thread Starter
So I went to the shop, and the radiator support did not look terrible, just a little rusted at the bottom, where the bushings connect (pretty usual i would assume) I didn't take any pictures. But this is the one that is for sale. is it the same?
71 72 Pontiac Lemans Parts
cdedic is offline
72 gto radiator core support STOP rusting Goat! 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-12-2010 05:12 PM
