1973 GTO transmission stuck - Pontiac GTO Forum
post #1 of 4 (permalink) Old 03-26-2012, 02:19 PM Thread Starter
hey if anyone can help me out id really appreciate it. i have a 1973 GTO lemans coupe with a 400cid v8 just got it running for the first time in 4 years of it sitting started fine i was driving it back n forth in the driveway it was going fine but the it just got stuck in gear when the shifter is in the neutral position i can let the clutch out and it still moves like its in gear but wont fully go into any of the 1-4 gears and when i put it in reverse and go to let the clutch out nothing happens an the car starts to stall also i can have the clutch in when its in reverse but the car wont move at all the tranny used to hang up every so often but i have no idea how i would get it unstuck or what not if anyone can give me advice id really appreciate it
ajgusty845 is offline
post #2 of 4 (permalink) Old 03-26-2012, 02:42 PM
blackplate65's Avatar
u should go under it and check the linkage out use jack stands though
blackplate65 is offline
post #3 of 4 (permalink) Old 03-26-2012, 04:01 PM
Shift linkage/shifter needs adjusting......SAFELY go under the car and put the 3 shifting arms on the trans. into the neutral position.
Eric Animal is offline
post #4 of 4 (permalink) Old 03-26-2012, 11:15 PM
jmt455's Avatar
There is a specific procedure to adjust the linkage.
First, support the car safely on jack stands or ramps, with the wheels chocked to prevent any movement.
Place the shifter in Neutral
If your car still has the column back-lock linkage, you need to loosen the swivel clamp at the bottom of the back-lock rod.
Loosen the jam nuts on the shifter rods.
Insert a 1/4" diameter gage pin through the shifter housing to lock all the levers and the shifter handle in the neutral position.
Position the shift levers on the transmission to the neutral positions, then adjust the shifter rod lengths as required to perfect align the rod ends with the shift levers.
Tighten the jam nuts, then pull the gage pin and verify that the shifter and rod adjustments are correct.
Finally, if your car has the reverse lockout, put the shifter in Reverse. Rotate the lower steering column lock collar to allow the igntion to be rotated to the "locked" position. Then lift up on the back-lock rod to remove the slcak from the linkage and tighten the swivel that you loosened at the beginning of the process.
If the shifter is located properly in the floor opening, that should do it.
If the shifter is NOT properly located in the floor opening, there is another set of steps required to re-set the shifter properly on the shifter support/trans bracket.
HTH
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
1973 455 with turbo 350 par4n1 1964-1974 Tempest, Lemans & GTO General Discussion 14 01-05-2012 08:56 PM
Car Radio 1973 GTO (looking) meligon 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 0 03-24-2011 01:59 PM
1973 400 rebuild skuzzzusmcdevildog 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 13 01-31-2011 09:48 AM
Exhaust question for a 1973 455 cmunson 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 3 04-21-2008 10:21 AM
06 GTO vs 1973 Firebird (455?) (400?) Robertr2000 Racing and Kill Forum 3 04-21-2006 05:23 PM
