2 lowering? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 03-29-2019, 04:58 PM Thread Starter
Anderslober's Avatar
Quoted: 24 Post(s)
2 lowering?
Hi forum.....do you guys recommend doing this?
I would maybe like to do it on the front.......spindles.....
Photos of setups would be appreciated......
Anderslober is online now
post #2 of 4 (permalink) Old 04-01-2019, 01:41 PM Thread Starter
Quoted: 24 Post(s)
Nobody?........is this a good idea? Lowering with springs.....or with spindles...?......or not at all....?
From new..the GTO`s had a slightly nose up stance.....I like level or slight nosedown stance........any ideas....? Thanks..
post #3 of 4 (permalink) Old 04-13-2019, 02:57 AM Thread Starter
Quoted: 24 Post(s)
I bought a new front disc brake conversion kit with 2 inch drop.....I hope this works and looks good. Otherwise, I`ll just go back to the stock spindles.
post #4 of 4 (permalink) Old 04-13-2019, 06:24 PM
Quoted: 153 Post(s)
There are kits that improve the geometry. I prefer lowering via coilovers as you still retain suspension travel (vs. shorter springs). The CPP 2" drop look nice (if that is what you did).
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
lowering question enjracing Drive train, suspension, alignment and brakes. 9 08-12-2006 05:31 PM
Lowering My 69 gto ragtop mueen 1964-1974 Tempest, Lemans & GTO General Discussion 7 07-07-2006 05:15 PM
