64 GTO rear end - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-23-2012, 05:51 PM Thread Starter
khinton's Avatar
64 GTO rear end
Im trying to find 3.08 or 3.23 for my car that for some reason has a 2.56 in it now. Does any one know where I can go to --I've had no luck -- all the gears I can find are 3.36 and higher.
khinton is offline
post #2 of 3 (permalink) Old 03-23-2012, 10:20 PM Thread Starter
khinton's Avatar
After further research looks like I will need the whole unit/carrier not just the gears--bummer --but I need the shorter gears with a four speed -- mine would be great in an auto trans.--Let me know if you have or know where I can get what I need--by the way mine is a perfect unit and would make a great cruiser for the right car.
khinton is offline
post #3 of 3 (permalink) Old 03-24-2012, 11:24 AM
Quoted: 119 Post(s)
Used is your best bet. When I re-geared my '65, I was lucky enough to be able to find a set of 3.36 gears that were in great shape that were compatible with my carrier. I would recommend Craigslist or Hemmings, etc, or the want ads here and on other forums. 3.08-3.23 rear ends complete, drum to drum, pop up fairly often. They made a lot of them. Good luck.
Hard to see rear of goat through inside rear view mirror common right?.... pctek 2004-2006 GTO General Discussion 8 11-22-2010 08:59 PM
?- looking for new rear end gears and rear suspension whytedude422 Service, Maintenance and Technical Discussion 3 03-31-2010 04:11 AM
