65 GTO axle swap - Pontiac GTO Forum
post #1 of 1 (permalink) Old 12-29-2015, 10:46 PM Thread Starter
65 GTO axle swap
My 65 has a 69 Olds O type axle under it. I want to change gears as it has a 2.78 open. Parts are hard to find and very expensive, However its supposed to be strong axle. My question is If I put in another axle out of a 67 and up abody that is 61" will I have a problem finding rims with proper backspacing. I plan on putting 17s on it. I read all kinds of stuff that says 65-66 10 bolts are easy to break ab 65 -67 12 bolt is hard to come by in good shape. Does anyone have a wider axle under the 65 and what backspacing did you go with. I have been researching alot and just not seeing answers I need. Thanks in advance
mjc707 is offline
1967 GTO 8.2 to 8.5 axle swap 67gtoconv 1964-1974 Tempest, Lemans & GTO General Discussion 2 06-17-2014 03:13 PM
Carrier Swap or Rear assembly swap AMT1379 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 07-21-2013 03:55 PM
Rear Axle Swap 68Temp 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 06-20-2012 12:14 AM
Rear Axle Swap 68GTO4004Spd 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 5 01-26-2012 09:33 PM
67 gto rear axle swap LTGOAT 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 10-20-2009 11:51 AM
