65 gto power steering pump - Pontiac GTO Forum
post #1 of 3 (permalink) Old 06-15-2018, 12:36 PM Thread Starter
65 GTO I replaced the power steering pump in my old reservoir because I could not find the exact replacement. Every thing works fine, but I have a very small seep where case (should seal) around the high pressure fitting. I got some neopreme washers with the pump, but no drawing to show where they would go. When I took it apart there was no washers there to create a seal between the pump and reservoir which may be why it had the leak originally. Does any one have a detail drawing of the pump to reservoir seal.
CDO
carmenoyloe is offline
post #2 of 3 (permalink) Old 06-15-2018, 11:02 PM
Quoted: 155 Post(s)
I am traveling but will post pictures from the service manual when I return....
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #3 of 3 (permalink) Old 06-15-2018, 11:35 PM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
BLK69JUDGE is online now
[B]Will power steering pump from a corvette work on a 06 GTO?[/B] Phoneticz Service, Maintenance and Technical Discussion 0 05-25-2015 12:36 PM
'67 GTO Power Steering Pump Goat Roper 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 01-21-2015 04:14 PM
Help with power steering pump on 68 GTO dimitri 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 9 12-02-2010 09:15 PM
65 GTo manual steering to power steering? d.reese 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 08-10-2009 06:51 PM
