'66 differential? - Pontiac GTO Forum
post #1 of 8 (permalink) Old 04-21-2018, 08:24 PM Thread Starter
'66 differential?
Hi Folks; I was hoping that someone could tell me what gears I have or even if I have an original GTO differential. The numbers I have on the differential do not match anything that I have found on the web. With my bad eyes it looks to be "J4 6" with "9788393".
Any help would be greatly appreciated!
Cheers
ID:	108930   Click image for larger version
ID:	108938   Click image for larger version
Cross's 66 is offline
post #2 of 8 (permalink) Old 04-22-2018, 05:23 AM
GTOJUNIOR's Avatar
Quoted: 66 Post(s)
It is a '66 but you need to locate the two letter code that should be on the RH axel tube to see what gear set was installed originally,
right of the vent on the rear facing out on tube is where they are commonly stamped.
ID:	109122   Click image for larger version
ID:	109130   Click image for larger version
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 8 (permalink) Old 04-23-2018, 09:07 PM
How many teeth do you have on the ring and pinion gears?
05GTO is online now
post #4 of 8 (permalink) Old 04-24-2018, 05:07 AM
GTOJUNIOR's Avatar
Quoted: 66 Post(s)
The one shown above was a 3:55
My '66 with AC has a 3:23
here it is before re-assembly many miles ago, don't recall tooth count.
post #5 of 8 (permalink) Old 04-28-2018, 08:47 PM Thread Starter
Hey guys, thanks very much for your help. Those alpha codes are small, I think I may have gone right over them without noticing! I did count the gear teeth and came up with 42 and 13; 3.23 ratio?
post #6 of 8 (permalink) Old 04-28-2018, 08:49 PM Thread Starter
I guess my other question would have to be around the type of rear-end. Is it a posi or not?
post #7 of 8 (permalink) Old 04-28-2018, 09:30 PM
Oem 8.2 Pontiac Safe-T-Track (posi) carrier. All oem Pontiac 8.2 STT carriers were cone type, hopefully cones have not bottomed out and carrier is no longer tight. If considerable wear on the cones will need disassembly, machining, shimming up, and reassembly.
post #8 of 8 (permalink) Old 04-28-2018, 09:37 PM Thread Starter
Hi PH, thanks very much! Unfortunately as a real dummy/newbie, I really dont know what you mean by cone type? How do I tell if they are bottomed out and need machining? Regards
Differential Berwick 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 2 04-02-2016 11:18 PM
differential 1965goat 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 0 09-10-2014 03:59 PM
Differential xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 06-09-2011 09:06 AM
differential ?? The intimidator Drive train, suspension, alignment and brakes. 6 03-16-2009 04:22 PM
Differential IPOCKALYPSE 2004-2006 GTO General Discussion 0 03-15-2005 08:24 PM
