66 gto installing 1972 12 posi coil spring selection - Pontiac GTO Forum
post #1 of 1 (permalink) Old 03-22-2016, 02:09 PM Thread Starter
I have 1966 GTO and I am installing a 12 posi rear from a 72 Monte Carlo. The spring perches are different than the original. The original ones are flat and have clamp to hold the spring down. Do I have to custom order springs or can i substitute spring from another year gto and or a different model Pontiac. Also I would like raise it up one inch from the stock height.
tonyli is offline
Installing a new posi and gears? MichaelG 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 03-27-2015 06:24 PM
Coil spring for '04 GTO crebrosseau Drive train, suspension, alignment and brakes. 1 08-18-2010 11:41 PM
Jetting and secondary spring selection Bensjammin66 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 07-16-2009 12:25 PM
Valve spring selection for new cam PAULCAPASSO Engine Discussions 24 02-27-2009 08:38 PM
