67 driveshaft - Pontiac GTO Forum
post #1 of 4 (permalink) Old 06-01-2018, 12:36 AM Thread Starter
67 driveshaft
Hello guys,
I picked up a 67 gto with a sbc 350 in it. It also has a th350 transmission. I don't know why it was put together like this but it runs and is in great shape. Problem is I can't find a driveshaft for it. I know the shaft will probably have to be longer than the original. Any ideas or places out there I can contact that may have one?
What vehicles out there are comparable that I can grab a driveshaft from given my configuration. It's hard to determine a measurement because I have no yoke either. Thanks in advance!
pmihelis is offline
post #2 of 4 (permalink) Old 06-01-2018, 05:38 PM
Quoted: 106 Post(s)
You can try Frank's Pontiac Parts but you will need a measurement from your tranny to center line of your rear end.
You may have to get a yoke for your tranny and have one made up by a company that makes them custom.
Scroll down.
https://www.frankspontiacparts.com/e...nsionparts.htm
Goat Roper is offline
post #3 of 4 (permalink) Old 06-01-2018, 06:54 PM Thread Starter
Thanks, I'll give it a try
pmihelis is offline
post #4 of 4 (permalink) Old 06-01-2018, 08:35 PM
Have 2 thick cardboard soap barrels with clean original GM A-body and F-body driveshafts sticking out the top of them. Usially sell 2 or 3 driveshafts a year, and thats typically when im building HD posi rears and coming in contact with guys that need a driveshaft as well. Shipping is what really hurts on driveshafts... I've always shipped in a PCV pipe & even with an acct, FedEx is expensive!
What part of the country are you in? Can possibly suggest a long time local vendor and then you can figure what center to center dimension driveshaft and if the GTO still has a bolt in axle 8.2 rear, or if rear has been swapped to a Chebby 10 bolt. Have seen it all!
Driveshaft Tj Ashworth 2004-2006 GTO General Discussion 5 01-12-2018 01:36 PM
Driveshaft SB71 Drive train, suspension, alignment and brakes. 6 08-19-2016 09:15 AM
Driveshaft GTODAVE05 2004-2006 GTO General Discussion 9 06-06-2005 08:44 AM
