67 Frame Body Mount Repair Opinions - Pontiac GTO Forum
post #1 of 16 (permalink) Old 02-06-2015, 03:40 PM Thread Starter
Quoted: 13 Post(s)
All,
I wanted to get your opinions on what is the best way to repair a rusted out frame body mount.
I have purchased the large washers that are sized correctly for an A-body frame repair.
As I see it, there are three options:
1) Cut out a hole the size of the washer and weld it in
2) Leave all the existing material and weld it over the rusted out section
2a)Do this on both sides to make that mounting point even on both sides.
3) Weld from underneath.
I would think that option 2 would be the strongest because it would leave the most material, but I worry that there would be a space between the repair washer and the old material giving a place for more rust to occur.
If option 2 is the best, do you think that I need a washer welded on both sides to keep it even? I wouldn't think that washer thickness would make that much difference.
I have added a few pictures as reference. The first picture is the rusted mount. Second is how I proposed to weld the washer on in option 2. Third is welding from underneath, and the fourth is the mount on the other side. You can see that mount is a little rusted, but not too bad.
Thanks in advance for your input.
Dan
ID:	51865   Click image for larger version
ID:	51873   Click image for larger version
ID:	51881   Click image for larger version
Colorado67GTO is online now
post #2 of 16 (permalink) Old 02-06-2015, 03:47 PM
Quoted: 106 Post(s)
I would weld the washer to the bottom then weld up the topside to fill then grind it flat so it is @ factory spec.
Goat Roper is offline
post #3 of 16 (permalink) Old 02-06-2015, 04:57 PM
I cut the hole to size of my patch body mount from my old frame and welded it flush.
Nightshade 68 HO is offline
post #4 of 16 (permalink) Old 02-06-2015, 05:19 PM
I offer option 4... cut them both off and weld new body mount brackets on from Ames Performance. $39 a piece. Matt
Matthew is offline
post #5 of 16 (permalink) Old 02-06-2015, 05:40 PM
Quoted: 11 Post(s)
05GTO is online now
post #6 of 16 (permalink) Old 02-06-2015, 05:41 PM
Have performed the first process many times on customer's frames.
Even if you are hamstrung with a minimum of tools; ie, Dremel cutoff tool, angle grinder, and a $100 arc welder, can perform a very clean repair.
post #7 of 16 (permalink) Old 02-06-2015, 06:53 PM Thread Starter
Quoted: 13 Post(s)
Thanks all for the input. I did briefly consider option 4, but it seems like there is so much more opportunity to screw it up. If I screw up one of the other options, I could always go to option 4. Also, even though I am not doing a concours restoration, the Ames bracket just looked so different from original.
I am leaning toward option 1 based on feedback, but will still welcome other opinions.
post #8 of 16 (permalink) Old 02-07-2015, 05:42 AM
Helmerrock's Avatar
I used a variation of option 1. Open up the hole in the hole in the rusted mount until you have good solid metal then turn the washer to fit the hole. then grind or file until the washer just fits the hole. Chamfer both the washer and the mount, tack weld first and then fill the chamfered groove. Grind top flush and it will be good as new.
Helmerrock is offline
post #9 of 16 (permalink) Old 02-07-2015, 10:06 AM
tiger13's Avatar
Yes, that is the option I would offer. Find a hole saw, and cut to fit the washer, tack weld in, do the same with the hole in the washer. Grind to finish. Makes a nice looking repair.
Rusty in NC
tiger13 is offline
post #10 of 16 (permalink) Old 02-07-2015, 10:45 PM Thread Starter
Quoted: 13 Post(s)
Thanks all. I am in the middle of the repair now. I basically chose option 1. I tried starting with a hole saw, but that really didn't work because the hole saw I bought didn't mount to my hole saw bit. Anyway, I used my dremel to cut out the old. I had to grind down the washer to make it fit and chamfered as Helmerrock said.
I had the luxury of being able to flip the frame over as it is stripped down now. I started with the underside and welded a bead around there. I then flipped the frame to the correct side and welded a bead on the top. I am in the process of grinding it down now. We will see how it turns out.
As someone on this forum said, "I may not be able to weld, but I can grind". I am not sure I am good at either, but I am learning.
I will post pictures when I am finished (if I am proud of the results ).
65 Gto body mount repair zzomby 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 14 04-04-2012 05:14 PM
frame repair RM9700 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 12 02-21-2012 02:03 AM
Repair Story...LS1...opinions? thecommish16 The Lounge 4 07-15-2007 11:08 AM
frame repair? ss1885 2004-2006 GTO General Discussion 1 01-24-2007 09:48 AM
67 GTO rear body mount repair fastgenious 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 1 10-22-2006 09:01 PM
