'67 GTO TH400 Hurst Shifter Adjustment - Pontiac GTO Forum
post #1 of 4 (permalink) Old 03-10-2018, 06:47 PM Thread Starter
Quoted: 14 Post(s)
Pushed forward it does not get into park. Going into reverse and drive the handle is about 1/2" too far forward. It seems the cable should be extended that much. I see no option of adjusting this. How does one fix this? Might I have an incorrect cable mount on the transmission?
I found this. https://www.gtoforum.com/f122/how-adj...hifter-101721/
And this: https://www.gtoforum.com/f122/his-her...-issue-118745/
Andrew69 is offline
post #2 of 4 (permalink) Old 03-12-2018, 10:59 AM
1968gto421's Avatar
Quoted: 72 Post(s)
Andrew, did you check out this one? Looking at the schematics should give you some idea about the cable mount correctness. Hope this is helpful.
https://www.gtoforum.com/f12/hurst-du...hematic-84090/
Hopefully others with more experience with these will chime in soon.
1968gto421 is offline
post #3 of 4 (permalink) Old 03-12-2018, 07:39 PM Thread Starter
Quoted: 14 Post(s)
Thanks. I figured I might have the wrong cable, or bracket or transmission lever. Don't know which so I slotted the bracket to allow adjustment and it works good now.
Andrew69 is offline
post #4 of 4 (permalink) Old 03-13-2018, 10:22 AM
1968gto421's Avatar
Quoted: 72 Post(s)
Good, glad things are working well now. Slotting the cable bracket was a good plan.
1970 GTO Hurst Shifter problem MJ1970 1964-1974 Tempest, Lemans & GTO General Discussion 2 06-23-2014 06:51 PM
TH400 shifter - console Hurst or B&M swap-out ques manfromnantucket 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 05-11-2014 10:54 AM
Like new 04 05 06 gto hurst shifter.. lasoya113 Drive train, suspension, alignment and brakes. 2 03-30-2011 03:32 AM
06 GTO Hurst shifter.. lasoya113 Drive train, suspension, alignment and brakes. 3 03-21-2011 01:48 PM
