67 Tempest transmission swap - Pontiac GTO Forum
post #1 of 17 (permalink) Old 01-03-2012, 05:05 AM Thread Starter
I am new to the forum and getting ready to restore a 67 Tempest with a 326. When all is done with the engine it should be around 350 hp. The car currently has the powerglide with column shift
I am deciding between the TH350 and a 200r4. I would like to have the overdrive on the 200r4 but from what I understand that involves moving the crossmember back and I am not excited about drilling new holes in the frame. Does the TH350 need the crossmember moved at all or is it a complete bolt on?
I also plan on switching to floor shift with a his/hers shifter and I think I need to buy the kit from shiftworks to make this work.
Has anyone done this before and can you please provide any insight.
Sent from my DROID BIONIC using AutoGuide.Com Free
67T3MP3ST is offline
post #2 of 17 (permalink) Old 01-03-2012, 03:13 PM
first off is that 350 hp out of the 326? if its the original automatic to the car and its a 2 speed then its not a powerglide has pontiac never used a chevy powerglide, they used the buick st300 two speed. if its the originalst300 then the crossmember dont have to be moved to put a th350 in, i been considering a 200r4 in my 66 tempest and been reading bout it, im not crazy bout drilling in the frame either and found that you can buy a aftermarket crossmember that will fit a 200r4 without having to drill new holes in the frame and if you use a his hers shifter there on convershion kits to convert one of those to work with a 4 speed auto.
danthepontiacman is offline
post #3 of 17 (permalink) Old 01-03-2012, 04:04 PM
Quoted: 119 Post(s)
A 200r4 will have to be worked over and upgraded quite a bit to handle 350 hp. They failed when they were behind 135HP 305 small blocks. They can and are a great upgrade, if built right. Not cheap, but your wallet will love you every time you cruise by a gas station without stopping to fill up.
post #4 of 17 (permalink) Old 01-03-2012, 05:46 PM
Quoted: 23 Post(s)
not sure but you may need the driveshaft re-worked for the 200R4 the TH350 is a straight drop in and go and you probably all ready have a Salt flats rear gear 2:56 or 2:7X so you would still be fine on mileage and freeway driving. They are cheap reliable and lighter mass than a TH400 . All depends on budget and what you want to do with the car. Shiftworks has everything you need for the shifter when you decide which route you are going.
Instg8ter is offline
post #5 of 17 (permalink) Old 01-03-2012, 08:05 PM
unless your ST300 is bad, not worth the expensive since the original dual gate alone is worth the price of a trans. not worth it for gas mileage either.
pontiac is offline
post #6 of 17 (permalink) Old 01-03-2012, 08:23 PM Thread Starter
It is the stock 326 with the 2 speed 67 Tempest 2bbl Its a matching numbers engine so I am going to keep it and rebuild it with a 4bbl. Stock it had 250 hp so the goal is 350 hp but I will be happy with anything over 300. (Heads redone with port/polish, cam, intake manifold, carb, headers, exhaust) But I will start a thread for the engine build when I get there.
Its a column shift automatic 2 speed transmission. I would like to change it to a floor shift with the hurst his/hers shifter and console. Going to get the shiftworks kit to make this happen.
I found a 67 column for floor shift but if anyone can help with where to get column bearings I would appreciate it. Also if anyone has rebuilt a column let me know too.
Back to the transmission. Sounds like the TH350 is a direct bolt in so thats what I will be going with. Now just got to find one. Also what stall should the converter be with engine I have planned? Was thinking of going as aggressive as 3.73 gears in the back b with a limited slip.
post #7 of 17 (permalink) Old 01-03-2012, 08:56 PM
Quoted: 23 Post(s)
make sure you get a BOP TH350, the bolt pattern is different on a chevy trans...
post #8 of 17 (permalink) Old 01-03-2012, 09:22 PM
Quoted: 119 Post(s)
3.73 gears are excellent if you drive the car in town or not very often. They are miserable on the highway without an overdrive trans....you're comfortable cruising speed will be about 58-60mph. Long trips will be a real grind. BTDT. Also, be prepared for poor fuel economy and accelerated engine wear, all compliments of a steep rear gear. My advice?? 3.23's in your rig with a TH350.
post #9 of 17 (permalink) Old 01-04-2012, 12:31 AM Thread Starter
I can just get the BOP bellhousing correct?
As for the gears the car will be my second vehicle for pleasure cruising. I live in Vegas so there is traffic most of the time. Just want to be able to jump on the accelerator occasionally off a light.
post #10 of 17 (permalink) Old 01-04-2012, 02:15 AM Thread Starter
Actually it looks like its all one piece. Thanks for the heads up
1966 Tempest disc swap aca70 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 04-15-2011 12:02 PM
transmission swap xcmac26 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 40 02-22-2011 11:14 AM
68 Tempest Restoration in process/Engine Swap FB68 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 10-17-2010 05:27 PM
68 Tempest Rear End Swap FB68 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 10-01-2010 10:59 PM
67 LeMans transmission swap aggie_67 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 13 03-31-2010 01:46 PM
