67 transmission cooler lines - Pontiac GTO Forum
post #1 of 8 (permalink) Old 03-27-2018, 09:55 PM Thread Starter
Hey all, first time posting here! So I have a 66 Tempest with a 68 400 and th400 tranny. I ordered new cooler lines for a 67 gto with a th400 but just wondering which line goes to which fittings on tranny and radiator? The lines that were in the car were cobbled so I just want to make sure I install these correctly. Thanks!
66Tempestcustom is offline
post #2 of 8 (permalink) Old 03-29-2018, 05:16 PM
Quoted: 13 Post(s)
Try these. These are from my 67 with a th400 and stock radiator. All pictures are taken from the passenger side.
ID:	107689   Click image for larger version
ID:	107697   Click image for larger version
ID:	107705   Click image for larger version
ID:	107713   Click image for larger version
Colorado67GTO is online now
post #3 of 8 (permalink) Old 06-15-2019, 04:16 PM
hilton8r's Avatar
I'm replacing the transmission cooler lines in my '67 GTO with turbo 400 trans. I got the lower one off no problem. How in the heck do you get to the top one? I can get a shorter 1/2" wrench on it, with the backing wrench, but I can't get any swing to break the nut. I don't have any line wrenches or crow's feet wrenches. Can it be removed with the transmission in place? I may just cut it to get a socket on it, but I'm still not sure how I'm going to get the new one on snug enough. I'll keep researching. Any advice would be appreciated. Now my keyboard is all dirty!
hilton8r is online now
post #4 of 8 (permalink) Old 06-15-2019, 07:30 PM
Quoted: 326 Post(s)
Maybe pull the dipstick tube? The bolt holds the bracket and there is an O-ring that fits around the tube and seals it as it is inserted into the trans.
post #5 of 8 (permalink) Old 06-15-2019, 07:33 PM
Lemans guy's Avatar
Quoted: 45 Post(s)
I use a crowfoot line wrench, a crowfoot flarenut wrench or a straight crowfoot....best one is the crowfoot line wrench, just use it with a ratchet and small extension, it will go on then. Do not overtighten those, you can easily crack the transmission case. Be a little lighter than normal, and it should be ok. Mine have mo leaks.
Probably a torque spec on it, I just donít recall it. With the crowfoot you can torque it....
Stay with it you will get it!
Lemans guy is offline
post #6 of 8 (permalink) Old Yesterday, 04:03 PM
hilton8r's Avatar
I thought about removing the dipstick tube. I wound up cutting the line, and removing with a socket. I was able to get the new line reattached using a much shorter wrench. I couldn't snug it up too tight if I wanted to with no room or swing... Hopefully mine won't leak either. If it does, I'll invest in some better wrenches for sure!
John
post #7 of 8 (permalink) Old Today, 01:09 PM
BLK69JUDGE's Avatar
Quoted: 44 Post(s)
slide a 12 point box end wrench all the way down the line from the radiator end
workss great then hook it up to the radiator
BLK69JUDGE is online now
post #8 of 8 (permalink) Old Today, 01:12 PM
hilton8r's Avatar
I did try that initially because the threaded end on the radiator side was missing from one of the lines. The wrench was too long for me to get it to where it needed to be. I'm sure that would have been perfect if I had tried it with a shorter wrench...
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
hilton8r
67 GTO HO trans cooler lines Lemans guy 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 6 08-24-2017 09:22 PM
HO exhaust transmission cooler lines routing? ucaddoc 1964-1974 Tempest, Lemans & GTO General Discussion 0 03-29-2017 12:36 PM
66 Lemans trans cooler lines Lemans guy 1964-1974 Tempest, Lemans & GTO General Discussion 4 10-15-2014 07:23 PM
Transmission Cooler timmyg 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 6 04-27-2012 10:57 PM
Trans cooler lines teamwoody72 1964-1974 Tempest, Lemans & GTO General Discussion 6 05-03-2009 06:37 AM
