68 4spd reverse switch location? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 11-12-2015, 08:59 PM Thread Starter
Anyone know where the back up light switch and bracket are located on a 68 GTO shouldn't it be somewhere on the trans linkage? If anyone has photos or knows where I can buy one please let me know.
frankrp is offline
post #2 of 3 (permalink) Old 11-12-2015, 10:17 PM
there is a steel tab piece that slides in and has a bent tab that holds the black plastic reverse light switch along with a thin spring steel clip. I have a complete '68 Firebird 400 shifter and it uses the same slide in piece with the tab.
Here's a link to a gallery of a '68 GTO shifter base from a long time seller on eBay.
inkFrog.
post #3 of 3 (permalink) Old 11-12-2015, 10:28 PM
Following is a link to another eBay auction. I only post it as it shows the shape of the reverse lever "kicker" . the linkage rods on an OEM Hurst 4 speed 68 and 69 Bird are the longest of any Pontiac application, as the shifter mounts further back and down low. The reverse rod is also longer, but the reverse lever with the kicker is the same as used with the '68 GTO Hurst 4 spd shifter.
RARE Original 68 1968 Firebird Hurst Shifter Shift Linkage Rods Muncie 4 Speed | eBay
70 Safety Neutral Switch Location ees41 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 04-19-2015 09:10 PM
1969 auto console shifter neutral safety switch mounting location chrisc1541 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 12-07-2010 09:30 PM
4 spd reverse switch questions tyler t 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 09-07-2010 07:33 AM
Location of Rear quarter Power Window switch for 70 GTO Convertible GQUINCOCES 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 0 02-09-2009 01:19 AM
