68 gas tank - Pontiac GTO Forum
post #1 of 5 (permalink) Old 12-02-2015, 03:32 PM Thread Starter
68 gas tank
does anyone know what kind of glue used on filler tube to tank
klem is offline
post #2 of 5 (permalink) Old 12-02-2015, 04:18 PM
Quoted: 106 Post(s)
It isn't glued it is soldered on.
Goat Roper is offline
post #3 of 5 (permalink) Old 01-02-2016, 08:24 PM
yep.
just took mine off the original tank to put on a new tank.
MAPP gas does a quick job of melting away the solder.
Just clean the tank thoroughly first.
I left the soapy water IN mine while I did it.
Oddly - many people will tell you to take it to a professional welder to swap them out.
Not necessary.
rlslavik is offline
post #4 of 5 (permalink) Old 01-22-2016, 10:56 PM
stoney200gto
It was originally soldered. i would use marine text epoxy. it is not affected by gas. I have repaired carburetors with it.
stoney200gto is offline
post #5 of 5 (permalink) Old 01-23-2016, 10:48 AM
Quoted: 106 Post(s)
I wouldn't use epoxy I filled my old tank with water and cut around the neck with a Sawzall and desoldered it from that piece.
LaCo paste and 60/40 solder with a propane torch to solder it to the new tank.
Air in the tank and soapy water solution to test for leaks and done in about an hour.
Don't use the newer lead free solder, the stuff is junk.
Gas tank help guyman 1964-1974 Tempest, Lemans & GTO General Discussion 6 07-12-2015 04:57 PM
Gas Tank Brace Logchain 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 06-11-2012 02:16 AM
68 Gas Tank dhinnah 1964-1974 Tempest, Lemans & GTO General Discussion 5 12-22-2010 10:12 PM
gas tank Topkat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 11-10-2010 01:12 PM
Aus gas tank vrs USA tank? GO-GTO! Service, Maintenance and Technical Discussion 23 03-04-2006 12:45 AM
