68 GTO Rear End Swap with 76 Cutlass - Pontiac GTO Forum
post #1 of 3 (permalink) Old 08-27-2018, 09:44 AM Thread Starter
John Schutt's Avatar
Quoted: 9 Post(s)
I have a 68 GTO with 3.08 Non-Posi, 8.2". In my search for a better rear end i came across a 76 Cutlass Rear end with 3:73 posi. Will this bolt in?
The GTO has a TH400 Transmission, please give thoughts on using this rear end.
Had same gears and posi in a '67 Cutlass, 330ci, and loved it.
John Schutt is offline
post #2 of 3 (permalink) Old 08-27-2018, 10:59 AM
deanhickey's Avatar
Quoted: 38 Post(s)
Hi John, I assume the th400 is a "PX" code. If your axel code is a "WE"code it is factory, a "YE" code would be with locking diff. It depends on what your trying to achieve. Are you looking for street or highway driving. If you have air conditioning that can be a factor. I am going by factory availability. you could go with a 3.36 or a 3.55 in the same carrier and even upgrade to a safety track rear end. Good luck with your decision hopefully some more knowledgeable members will wade in. The more info you give the better answers you get.
deanhickey is offline
post #3 of 3 (permalink) Old 08-28-2018, 09:34 AM Thread Starter
Quoted: 9 Post(s)
No AC on my GTO,this will be a daily driver, some highway, i haven't had the engine apart yet but guessing its pretty much stock, I won't be overpowering the rear end.
Will a 76 cutlass rear end bolt in to a 68 GTO?
I have a flywheel question 70 motor swap 76 70droptopgoat 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 10-29-2011 07:33 AM
68 Tempest Rear End Swap FB68 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 10-01-2010 10:59 PM
Sales are up 76.9 percent through May Palmer In the News 1 06-26-2005 11:53 PM
