69 gto 10 bolt axle - Pontiac GTO Forum
 1Likes
  • 1 Post By Pinion head
post #1 of 2 (permalink) Old 05-21-2017, 05:41 PM Thread Starter
69 gto 10 bolt axle
Hi all ' I'm new to this forum and need some tech help! How much hp could I put through my 69 gto 10 bolt axle running on standard wheels and tires?
Judge501 is offline
post #2 of 2 (permalink) Old 05-21-2017, 10:48 PM
Welcome to the forum. How much hp? Believe you mean how much Torque. How much will depend on the style of rearend & how the rear is torque loaded.
-Near flawless condition A-body HD Safe-T-Track Pontiac 8.2 10 bolts have been run routinely down into low 12's in the 1/4 mile on PolyGlas & Wide Oval G70-14's, Pure Stock Drags & other venues. Near 450 gross hp/3750-3800 lbs with driver.
-In lightweight early RA Firebirds, a few well prepped Pontiac HD 8.2 STT rearends have been known to live down into the high 10's on slicks.
-With the small pinions of 3.90, 4.10, 4.33, & 4.56 Pontiac 8.2 gearsets, the nodular iron center housing incorporated in the special HD STT rears helped minimize pinion deflection. Pinion deflection is what will eventually take out a gray iron 8.2 rear ESP when built with a small pinion & thick ring gear & subjected to repetitive hard launches. The standard duty 8.2 axles just like the gray iron standard center housings are both a huge weak point.
Have repeated this so any times, but some don't get it. Unfortunately, the vast majority of Pontiac 8.2 rears are not HD Safe-T-Track rears, less than 1% are, instead, the typical 8.2 10 bolt consists of a weak gray iron 8.2 housing with standard duty axles. Having picked up the pieces from way too many blown up gray iron posi 8.2 rears, as a differential builder, it's just much easier to not throw waaay over a $1000 into "upgrading" a gray iron housing 8.2 rear with Moser axles, new gears, & a Auburn Pro Series or Eaton posi carrier. Maintaining or building a putt-a- round cruiser, the gray iron 8.2's can live a long life. Attempting to repetitively throw 100-200 more ft lbs of torque at the R&P in the weak gray iron housing, than what this differential was designed for, the limit will be reached even in a 3700 lb A-body that can only 60 ft in the high 1.8's on bias plys.
curtis.smith68 likes this.
69 gto 10 bolt axle Judge501 Member Introductions 0 05-21-2017 05:25 PM
Need a 10 bolt axle shaft FlambeauHO 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 13 04-17-2012 04:47 PM
Is the 10 Bolt 8.2 BOP Carrier the same as Chevy 10 Bolt? mighty454 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 04-21-2010 03:30 PM
10 Bolt Versus 12 Bolt Rear Axle take5 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 09-28-2009 03:45 PM
69 GTO 10 bolt non-posi convert to 12 bolt posi AzStateFan 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 09-12-2009 04:34 PM
