69 GTO 12-bolt driveshaft - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-09-2011, 09:37 AM Thread Starter
I have a '69 GTO with a Pontiac 400 TH-400 transmission and I have just recently purchased a 12-bolt rear end out of a '69 Cutlass. I am wondering if I need to get my driveshaft shortened of if I should just buy a new one?
'81 Regal, Daily Driver.
'69 GTO, Lifelong Project.
'91 S-10, Auto-X Project?
liljohn442 is offline
post #2 of 3 (permalink) Old 12-09-2011, 03:49 PM
You could always just try it and see if it fits. It might be close. Make sure the yoke on the 12 bolt is the same size/shape in all respects as the original. Also... you said "12 bolt out of a 69 Cutlass".
Hate to be the one to break it to you but there's a good chance that's not a 'real' 12-bolt. The number of bolts on the rear cover mean nothing --- what counts is the number of bolts inside securing the ring gear to the carrier. There were some GM 10-bolt rears made in that time frame (usually found on Oldsmobile and Buick) that had 12-bolt rear covers on them. I've got one in my spare parts pile, or did at one time.
You should be able to research it on the net, or pull the cover and count ring gear bolts.
post #3 of 3 (permalink) Old 12-12-2011, 07:31 PM
You might be able to get by with just a conversion u-joint.
And if you pull the cover, set the axle tubes on some jack stands with the yoke facing down and then when you pull the cover you won't lose the fluid.
Driveshaft 04 GTO wildchild405 Drive train, suspension, alignment and brakes. 0 10-10-2011 05:03 PM
Is the 10 Bolt 8.2 BOP Carrier the same as Chevy 10 Bolt? mighty454 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 04-21-2010 04:30 PM
10 Bolt Versus 12 Bolt Rear Axle take5 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 09-28-2009 04:45 PM
Driveshaft GTODAVE05 2004-2006 GTO General Discussion 9 06-06-2005 09:44 AM
