70 GTO Transmission damaged and leak - Pontiac GTO Forum
post #1 of 5 (permalink) Old 11-24-2014, 04:02 PM Thread Starter
Hello everyone,
First I wanna start and say when I got the car from my uncle it wasn't running. I had to change couple of stuff for the car is running. Also I found out that oem transmission filler tube is bend and leaking bad. There are two types of seals, o-ring and a rubber sleeve type seal depend on your filler tube style I guess. My TH350 filler tube had the rubber sleeve . I ordered the rubber sleeve online and bought Mr. Gasket. Filler tube Found out it has the o-ring. The Mr. Gasket tube tip is thicker then oem that's why it has O-ring and oem skinny and have rubber sleeve. To make the story short I installed the Mr.gasket with O-ring. Filed the transmission fluid car ran once I turned it off and let it set fluid started leaking I think from the dipstick. Is it because it's cheap brand and O-ring isn't sealing well? Should I switch to the rubber sleeve kind? Should I keep it and add ultra grey gasket maker and let it dry over night?
Or should I buy this dipstick?
http://www.summitracing.com/parts/tci-743860/overview/
A Stallion is offline
post #2 of 5 (permalink) Old 11-24-2014, 04:05 PM Thread Starter
Picture of the leak and also the link a video of it :
https://www.dropbox.com/s/t1xiay17lx...%20PM.mov?dl=0
post #3 of 5 (permalink) Old 11-24-2014, 04:24 PM
Could be you might have damaged the o-ring during the install?
post #4 of 5 (permalink) Old 11-24-2014, 06:03 PM Thread Starter
So should I just use the ultra grey gasket maker around the end of the dipstick around the o-ring?
post #5 of 5 (permalink) Old 11-24-2014, 07:19 PM
Quoted: 404 Post(s)
Get a new rubber O-ring at your local parts store like NAPA, they should have no problem matching it up. Could also go to a trans shop as they should be able to help with an O-ring as well. You can get O-rings in differing sizes/thicknesses so if the one you had was actually too small, you can get a larger one. Sometimes you can purchase an O-ring kit in a box that has assorted sizes if worse comes to worse.
You don't want to use any sealant as you don't want any of it floating around in your trans should some of it get below the O-ring and flake off.
Always put some trans fluid on the O-ring to act as a lubricant prior to installation. Also make sure it gets pushed in deep enough to seat it.
Transmission leak continues despite repairs jimmy328 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 06-03-2012 10:51 PM
Transmission leak NEEDLEZ 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 42 10-15-2011 04:25 PM
Transmission leak TxSoldier6.0 Drive train, suspension, alignment and brakes. 3 06-02-2011 12:45 AM
68 Transmission Leak - Thoughts? cgseaman 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 5 09-16-2010 11:26 PM
Transmission Leak Jerry Libes 2004-2006 GTO General Discussion 0 05-18-2005 09:41 AM
