74 GTO Automatic Transmission Downshift - Pontiac GTO Forum
post #1 of 1 (permalink) Old 08-24-2015, 02:12 AM Thread Starter
Red74Goat's Avatar
Quoted: 4 Post(s)
My '74 GTO has the original M-38 turbo hydramatic three speed transmission. It spent many years in the garage, not being driven, just being occasionally started and driven a few feet, never getting out of 1st gear. Less than 30,000 miles on the car.
The transmission runs okay, but won't downshift with WOT. I adjusted the detent cable and still doesn't downshift. Trans fluid level is not low. I'm assuming some problem with the governor or valves sticking, possibly as a result of sitting around with little action for so many years. Any suggestions of what I might be able to try before I end up having to drop the trans oil pan and start working under the car with transmission oil running up my arm!
Thanks for any suggestions.
Red74Goat is offline
2006 GTO LS2 Automatic Transmission problems Tennessee 2004-2006 GTO General Discussion 3 08-10-2014 02:35 PM
GTO 69' Automatic transmission problem. waernes 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 07-05-2014 01:57 AM
67 GTO with leaking transmission; automatic jimmy328 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 04-27-2012 11:42 PM
Automatic Vs. Manual Transmission drosene Service, Maintenance and Technical Discussion 17 09-11-2007 05:06 PM
Auto transmission Downshift Question rxdoc Service, Maintenance and Technical Discussion 6 12-30-2004 06:42 PM
