Another Axle Question - Pontiac GTO Forum
post #1 of 8 (permalink) Old 06-19-2017, 07:10 PM Thread Starter
Quoted: 9 Post(s)
I also need to replace a bent axle and am confused as to how to measure the length. My rear end is not original to my car (69 tempest) but did come from a 1970 vintage car. It uses set9 bearings and has 28 splines and is a bolt on axle. If I order a 29.5" length, am I ok? I'm measuring from the inside of the hub flange to the end of the splines. Or should I be measuring to the outside of the hub flange which is 29.875"
Thanks for your help
ajluzi1957 is online now
post #2 of 8 (permalink) Old 06-20-2017, 12:19 PM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
Hi
That looks to be a 71 72 8.5 " ring gear axle
I have nice used for 80 shipped ..50 axle 30 shipping
Scott
206 465 9165
BLK69JUDGE is online now
post #3 of 8 (permalink) Old 06-20-2017, 02:10 PM
How many access holes are in the axle flange?
-if only one access hole, the axle is a '70-72 Pontiac 8.2 axle, and you know what you need. This style of axle is not that hard to find & as A9 bearings next to never seize, as such the standard duty 70-72 Pontiac 8.2 axles are relatively easy to find used, the hot forged versions found in '70-71 HD SST Pontiac 8.2 rears are another story, if missing, next to impossible to find, best to just call Moser & buy a quality replacement set.
-if there ar 3 or 4 access holes in axle flange, the axle could be a '71-72 8.5 A-body axle, it could also be a '70 Type "O" axle, or a '70 BUICK 8.2 axle. All are different rearends & were assembled new with their own style of axle which used an A9 axle bearing. The 1970 Type "O" and the '71-72 8.5 A-body housings were also built to acceept A10 axles.
Of the four different style rearends/ axles listed above there are actually 3 different pitch 28 spline axles. One can't simply install the common '71-72 8.5 Abody axle in the 8.2 Pontiac carrier, it won't slide in. All the above is just one reason, there is no such thing as a BOP 8.2 reared, that unfortunately is a term bred from ignorance & repeated over...
Feel free & post back with how many access holes & I can further identify.
post #4 of 8 (permalink) Old 06-20-2017, 03:11 PM Thread Starter
Quoted: 9 Post(s)
Wow, thank you for the detailed information! Didn't realize it could be that complicated! There is only one access hole in the flange. Also, the carrier has a casting date code of June 1970. so it would appear that I have the common 70-72 8.2
post #5 of 8 (permalink) Old 06-20-2017, 03:46 PM
Will ck what axles have already moved to my new building. If none there, will be hauling more parts in tonight & will ck the housing racks, should have several of this style.
post #6 of 8 (permalink) Old 06-21-2017, 10:04 AM
Quickly looked at axles have already moved, no single hole '70-72 Pontiacs have made it this way yet. Picked up a flat on the loader late afternoon, so did not get out to my old warehouse. Flat fixed, heading out for another load little after noon.
post #7 of 8 (permalink) Old 06-21-2017, 10:48 AM Thread Starter
Quoted: 9 Post(s)
Thanks Pinion Head, I may have found one here in CT.
post #8 of 8 (permalink) Old 06-21-2017, 01:24 PM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
axle
pics of my spare
ID:	92249   Click image for larger version
1965 Rear axle question 19GTO65 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 10 01-17-2016 02:41 PM
Another Axle Code Question zrsteve 1964-1974 Tempest, Lemans & GTO General Discussion 4 09-14-2015 06:50 PM
1967 Rear Axle Question GTO4UNME 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 5 09-28-2014 08:49 PM
Rear axle question 68GTO4004Spd 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 5 06-27-2011 07:02 PM
1968 rear axle question JS_Bethlehem 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 12-03-2005 08:31 PM
