Automatic transmission fluid - Pontiac GTO Forum
post #1 of 3 (permalink) Old 07-25-2015, 03:51 PM Thread Starter
I just put a new gasket on my 1966 GTO automatic transmission pan. Does anyone know how much ATF fluid goes back in the tranny? The '66 book says 3 quarts, then another place says 22.5 pints. I don't know...
Thanks.
.....Mark
Markd15668 is offline
post #2 of 3 (permalink) Old 07-25-2015, 04:59 PM
rickm's Avatar
Quoted: 5 Post(s)
stock 2-speed automatic trans.? my '65 shop manual says to refill after replacing pan gasket, add 5 pints then run for 3-5 minutes in park to warm the fluid. check dipstick and add as required to bring fluid level to the full mark. DO NOT OVERFILL! that's what it says in the '65 shop manual.
rickm is offline
post #3 of 3 (permalink) Old 07-27-2015, 10:30 PM
Also could be that the two capacities you found differed because one included the torque converter and one did not. I like what rickm said. Add enough so that you can see it on the dipstick, then warm it up and top it off.
Change Automatic Transmission Fluid and Filter iwant2buyaGTO Service, Maintenance and Technical Discussion 8 08-16-2014 04:58 PM
Automatic Transmission Rebuild Roland Short 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 08-03-2014 06:41 PM
Automatic Transmission fluid change/details Rgrafton Service, Maintenance and Technical Discussion 5 04-09-2014 04:00 PM
Automatic transmission fluid for power steering? iwant2buyaGTO Service, Maintenance and Technical Discussion 5 02-09-2012 08:25 PM
Automatic Vs. Manual Transmission drosene Service, Maintenance and Technical Discussion 17 09-11-2007 05:06 PM
