Axle issues - New to me 67 Le mans - Pontiac GTO Forum
post #1 of 6 (permalink) Old 06-19-2017, 05:57 PM Thread Starter
Great site. Thank you in advance to all the people that take the time to help newbies like me out. With less than 200 miles on the car by me. 1967 Le mans 326 automatic Convertible. The rear axle started chirping and then grinding. I pulled the drum and axle and found A rear bearing blew and tore up the driver side axle. I found a few used axles near by but they were scored or the wrong type for a C clip axle. Mine is bolt on not C Clip. I found a code on passenger rear of tube but I cannot match it up. K016 over 9783393. i measured the axle 29 3/4" from outside to end of spline (28 Spline)
I need 2 new axles to get me back on the road now that the sun is shining in beautiful Northern Illinois.
jgardner is offline
post #2 of 6 (permalink) Old 06-19-2017, 06:53 PM
Quoted: 106 Post(s)
Welcome to the forum JG.
Summit Racing part # SPZ-35060 399 bucks for a pair.
https://www.summitracing.com/int/par...-size/5-3l-326
Press on bearings and these axles come with 2 press on spacers for the proper depth.
Goat Roper is offline
post #3 of 6 (permalink) Old 06-19-2017, 07:21 PM
Quoted: 9 Post(s)
Hi,
Rock Auto has the same axles for $103 each plus you can use this for an extra 5%. Put this in the " how did you hear about us" box 6377581255213358
ajluzi1957 is online now
post #4 of 6 (permalink) Old 06-19-2017, 08:12 PM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
pm sent
I have nice original pair from a low mile 4 door 8.2 bolt in axle bop
nice lug studs ..
Scott
BLK69JUDGE is online now
post #5 of 6 (permalink) Old 06-19-2017, 10:00 PM Thread Starter
Thank you for re assuring my research. Having the support to identify the right part helps a ton. I am going premium.
jgardner is offline
post #6 of 6 (permalink) Old 06-19-2017, 10:10 PM Thread Starter
thank you the coupon worked - order complete
jgardner is offline
my 65 le mans restroration ijason73 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 09-09-2014 05:50 PM
66 Le Mans in Nebraska jcorkin Member Introductions 2 08-23-2014 09:07 AM
Need '67 Le Mans or GTO convert... Uly49 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 03-18-2011 11:53 AM
RE: One mans take on our future PDQ GTO The Lounge 4 03-06-2009 06:09 AM
