Bad news rear end - Pontiac GTO Forum
 7Likes
post #1 of 18 (permalink) Old 04-30-2018, 01:04 PM Thread Starter
denrael's Avatar
Quoted: 9 Post(s)
Bad news rear end
The photos below show what I found when I opened up the diff on the '67 that I took delivery of just last week. After hearing a "CLANK" emanating from the rear for about the 3rd time in the 50 or so miles I've driven the car, I thought it might be prudent to do some investigation. Oh man! Between this and the disintegrated RF brake shoe (sticking wheel cylinder), I think it's time I had a talk with the seller... I'm wondering what other disasters are waiting to happen.
ID:	109954   Click image for larger version
ID:	109962   Click image for larger version
denrael is offline
post #2 of 18 (permalink) Old 04-30-2018, 04:21 PM
GTOJUNIOR's Avatar
Quoted: 66 Post(s)
Holly crap you better check every fastener on the car after finding that mess.
Best of luck.
Cheers
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 18 (permalink) Old 04-30-2018, 04:30 PM
Quoted: 106 Post(s)
Ouch!
I moved your thread and added a descriptor so the rear end guys will see your post.
Good luck, my parts matching turnkey '67 GTO was actually turnkey 3 years after I bought it.
JNYBOY and denrael like this.
Goat Roper is offline
post #4 of 18 (permalink) Old 04-30-2018, 06:55 PM
Quoted: 401 Post(s)
A little scary. Right brake worn? I can't tell from the pics if you have posi or not, but if you don't, I would suspect that the previous owner was having a little fun and locking the brakes to keep one side from spinning and smoking the heck out of the other tire.............not that I would ever do something like that.
Hopefully nothing was damaged or gears chipped and it'll be a simple fix and it'll be on the road.
post #5 of 18 (permalink) Old 04-30-2018, 07:27 PM Thread Starter
denrael's Avatar
Quoted: 9 Post(s)
Best of luck.
Cheers
You're absolutely correct... hard at it as we speak.
denrael is offline
post #6 of 18 (permalink) Old 04-30-2018, 07:29 PM Thread Starter
denrael's Avatar
Quoted: 9 Post(s)
Originally Posted by Goat Roper View Post
Ouch!
Thanks... I totally missed this sub-forum when I took a quick look. I'll get better as we go along.
I hear ya on the 3 year thing. If only this car was half as good mechanically as it is cosmetically...
denrael is offline
post #7 of 18 (permalink) Old 04-30-2018, 07:41 PM Thread Starter
denrael's Avatar
Quoted: 9 Post(s)
Naah... the brake was a completely unrelated failure. Either the wheel cylinder was sticking or the flex hose was collapsed and trapping pressure. In either case, the RF was intermittently dragging heavily enough that it cooked big chunks of lining off the shoe. I suspect the shoes weren't exactly top notch pieces to start with.
Glad you brought up the posi... yes, it does. But I don't know what type, I'm not that familiar with all the various types of limited-slip units. Here's a photo that shows the cage... anyone care to hazard a guess as to type? I need to know what the recommended lubricant is, before I put it back together. (I'm satisfied I've found all the errant pieces and there is no real damage to the gearset, so it's just clean up the mess and put in new bolts - properly TORQUED!)
ID:	110034   Click image for larger version
denrael is offline
post #8 of 18 (permalink) Old 04-30-2018, 07:53 PM
Quoted: 106 Post(s)
That was my goat paint and livery done and the good thing was mechanically it was all original and untouched the bad thing was it was all original and untouched.
Make sure you flush that rear end out well and use brake clean on the threads before installing the new bolts and torque them to spec.
1968gto421 likes this.
post #9 of 18 (permalink) Old 04-30-2018, 07:53 PM
Quoted: 401 Post(s)
Ah, ok on the known wheel problem, and not "burning outs."
I strongly suggest you either send a Personal Message to member Pinion head or just wait a bit for him to read your post as he is the expert/rebuilder of Pontiac & other GM rear-end assemblies. He will tell you what to use for oils and ID that posi for you and what to look for.
denrael likes this.
post #10 of 18 (permalink) Old 05-02-2018, 06:48 AM Thread Starter
denrael's Avatar
Quoted: 9 Post(s)
Unfortunately, his message box is full, won't accept any new correspondence.
denrael is offline
bad news.... rextheracer 2004-2006 GTO General Discussion 10 06-15-2009 05:10 PM
Good News, bad news... PwrGTOGuy 2004-2006 GTO General Discussion 0 03-03-2007 10:01 PM
Really bad news kanibal Drive train, suspension, alignment and brakes. 5 02-01-2007 10:32 PM
good news and bad news dustyminpin 2004-2006 GTO General Discussion 1 10-25-2006 08:21 PM
Good News, Bad News. GTO Gone Again gtotgo 2004-2006 GTO General Discussion 4 03-22-2006 05:15 PM
