Best coil springs? - Pontiac GTO Forum
 3Likes
  • 1 Post By 1968gto421
  • 2 Post By WideTrack
post #1 of 10 (permalink) Old 03-24-2019, 12:12 PM Thread Starter
Anderslober's Avatar
Quoted: 24 Post(s)
Best coil springs?
I need new front and rear coil springs for my 68 GTO conv. I am only interested in stock ride height.
Which springs are you all using?
I would like firm/heavy duty springs....I guess.....
Please mention a few options...thanks...
Anderslober is offline
post #2 of 10 (permalink) Old 03-25-2019, 09:36 AM
Quoted: 162 Post(s)
Since you already know you want stock ride height and are not going coilovers, I am guessing you want a stock replacement. Just get the OE replacement and be done with it. Most of the time people are concerned because of changing the height or wanting a much stiffer ride, but in your case that does not appear to be the driver....
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #3 of 10 (permalink) Old 03-25-2019, 10:14 AM
1968gto421's Avatar
Quoted: 72 Post(s)
Member Pinion Head who has been a long time forum expert on this topic has recommended Coil Spring Specialties as the best source to use. Since you want stock height and firm, CSS sounds like the place to contact.
Here is their site:
Coil Spring Specialties | Classic Cars
Best of luck!
cij911 likes this.
1968gto421 is offline
post #4 of 10 (permalink) Old 03-25-2019, 09:42 PM
I got my front and rear coils from Eaton Detroit Spring, in Detroit. I live close by so I've been to their shop. Same location it's been for many years, in the shadow of the old Tiger Stadium at Michigan and Trumbull. I have no problem recommending them. Pretty sure I've purchased other stuff from them too. Body bushings, core support bushings, etc. They manufacture their springs right there on site.
https://www.eatondetroitspring.com/
https://www.eatondetroitspring.com/make/pontiac/
1968gto421 and cij911 like this.
WideTrack is offline
post #5 of 10 (permalink) Old 03-26-2019, 12:42 AM
dcoydad's Avatar
Quoted: 6 Post(s)
I went with Moog springs. Talked to a tech on the phone and he hooked me up with front and backs. I have an AC car so stiffer than non and also used the heavier cargo springs in the rear. Perfect stance and ride.
dcoydad is offline
post #6 of 10 (permalink) Old 03-26-2019, 03:56 AM Thread Starter
Quoted: 24 Post(s)
Thanks for the great info. I will look into Eaton and CSS.
Dcoydad......what Moogs did you use? Part numbers?
I have seen some Acdelco (variable) coils......they seem fine.....45H3095......any good? Thanks.
Eaton and CSS are really, really nice...but..wow....they are a bit expensive....and I need shipping to Denmark....ouch...
post #7 of 10 (permalink) Old 03-27-2019, 07:03 PM
gtojoe68's Avatar
Quoted: 8 Post(s)
I bought a complete front end rebuild package from Ames - used all stock parts, mostly Moog. Couldn't be happier. Recommend switching to disc brakes at the same time - unless you already have. the disc brake conversion lit was supplied by The Right Stuff. I too have a 68' conv.
gtojoe68 is offline
post #8 of 10 (permalink) Old 03-29-2019, 06:20 PM
integrity6987's Avatar
Quoted: 51 Post(s)
member snoslyd has it right for our awesome cars - his signature is: G.O.A.T - Get Out Another Thousand
DK
integrity6987 is offline
post #9 of 10 (permalink) Old 03-31-2019, 09:41 PM
Quoted: 33 Post(s)
I also replaced with Ames recommended springs.
tjs72goat is offline
post #10 of 10 (permalink) Old 04-11-2019, 04:21 AM Thread Starter
Quoted: 24 Post(s)
I ordered the Acdelco`s.......front and back. Hopefully they are awesome!
Installing front coil springs...need advice ponchonorm 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 15 08-19-2015 07:15 PM
rear coil springs instead of leaf springs jtwoods4 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 9 01-02-2012 10:52 PM
Heated Front Coil Springs On '66 Gto take5 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 09-11-2009 11:16 PM
Coil Springs? ponchonorm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 07-23-2009 05:06 PM
