Body bolt torque spec - Pontiac GTO Forum
post #1 of 2 (permalink) Old 01-20-2018, 09:59 AM Thread Starter
Hello all,
i have a 69 GTO convertible that I've just replaced the body bushings with a stock set from resto parts/ OPG, i was ablate remove all but 2 bushing bolts that required meet cut the old cage nut out. I've replaced the cage nuts and have all the bolts back in torqued at a nominal 25 ftlb, but i have not found what the recommended torque is for them. the assembly manual for 69 says 25-45 ftlbs but I've found nothing more specific than that.
info greatly appreciated.
Shadetree Racing is offline
post #2 of 2 (permalink) Old 01-20-2018, 08:35 PM
Quoted: 33 Post(s)
It seems somewhere it was discussed to be 40 ft. lbs.
tjs72goat is offline
69 lower control arm mounting torque spec dan woodland 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 08-22-2014 06:25 PM
pontiac 400 harmonic balancer torque spec? 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 12-16-2012 09:26 AM
I have 2 torque spec questions 68gtohawk8369 1964-1974 Tempest, Lemans & GTO General Discussion 4 04-30-2010 07:17 PM
torque spec question bobby326 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 04-25-2010 02:18 PM
Axle Flange torque spec? MaL 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 06-12-2009 04:27 PM
