Body mount bushings - Pontiac GTO Forum
post #1 of 5 (permalink) Old 10-02-2018, 12:29 AM Thread Starter
Fxnjetz56's Avatar
Body mount bushings
Looking at the Tempest service manual, it refers to different color body mount bushings.
Does this signify different material composition? Size ? Etc?
None of the replacement kits I’ve seen, seem to make any distinction in this regard.
Anyone have experience with this?
Fxnjetz56 is offline
post #2 of 5 (permalink) Old 10-02-2018, 04:27 AM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
It's been discussed in the past by some of the hardcore resto folks that it was some sort of anti corrosion coating,
while others state it was so the line person could quickly ID the mounts needed for a particular model.
This makes more sense to me then a corrosion protection.
Think about the varying mount sizes per model and then depending on assembly plant that made several divisions of GM cars it was likely just that.
A quicker way to ID the needed mount.
Name:	BLUE MOUNT.jpg
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 5 (permalink) Old 10-02-2018, 12:02 PM Thread Starter
Fxnjetz56's Avatar
Thank You for your reply...the notion of quick ID on the assembly line makes sense to me. Iíve seen a fair amount of discussion on replacing mounts on my searches here, many folks replacing them, without issue as regards colors. Iíll likely just order the full kit from OPGI...
post #4 of 5 (permalink) Old 10-02-2018, 03:17 PM
Quoted: 13 Post(s)
I believe the color denotes size. On my 67, a couple of the standard bushings were too big for the frame holes. I just cut them down as I am not going to that level of restore, but there are definitely different size bushings for different frame locations.
Colorado67GTO is online now
post #5 of 5 (permalink) Old 10-08-2018, 05:48 PM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
Was looking through some files and forgot I had some Crash Sheets. This page details Color Codes.
What it does not show are the "PUCKS" I have come across more then once?
Body mount bushings orelog 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 8 11-08-2015 08:56 AM
Strut mount bushings and Bearings NucciGOAT Drive train, suspension, alignment and brakes. 6 12-13-2013 06:45 PM
65 Gto Body Bushings zzomby 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 09-20-2010 03:22 PM
Body Bushings ChromeShopJoe 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-06-2009 02:32 PM
69 GTO Body Bushings WillieF 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 05-06-2008 06:16 AM
