Boxed frame restoration - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-17-2015, 03:01 PM Thread Starter
When restoring a convertible boxed frame, how is the interior of the box cleaned and restored?
Shadetree Racing is offline
post #2 of 3 (permalink) Old 12-17-2015, 04:25 PM
How rusty is the frame? Are you in an area of the country that the roads get really nasty in the winter, and you plan on driving the car in those conditions? In the '90's I used a local Redi Strip franchise on trailer loads of nice sheet metal, wheels, front control arms, r/e housings. The mgr was giving me a smoking deal before the biz was closing. Redi Strip uses a reverse electrolysis system in their tanks. When done, they pull the metal out and power wash it off, and if the bare metal is going to set around a while, they mist the metal with a glycol solution. The glycol is a mess, needs to be power washed and scotch brited off, need to use new cotton gloves loading it up, or there will be finger print stains on the shiny metal.. I would have no problem, using that process on a frame. have pulled and sold tons of clean Southwest frames out of A body partcars, I usually blast them for my own use, of course that doesn't get inside the front crossmember or boxed side rails on a convert frame
post #3 of 3 (permalink) Old 12-17-2015, 05:32 PM
Quoted: 11 Post(s)
Here is a company just north of you in Indy that can dip your frame;
Redi Strip Indy - Precision Metal Cleaning
05GTO is offline
Start a frame off restoration or not Keen3689 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 14 03-25-2015 09:56 AM
Frame-off restoration rmfowler 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 08-27-2012 09:10 PM
71 Lemans First Frame Off Restoration OrbitOrange 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 88 09-20-2011 02:06 PM
69 gto off frame restoration Poncho 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 08-30-2011 03:15 PM
boxed frame pics bobby326 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 8 12-23-2010 08:35 PM
