Can I use GM truck rear end and tranny?? - Pontiac GTO Forum
post #1 of 14 (permalink) Old 01-12-2012, 07:15 AM Thread Starter
SPCMarty's Avatar
Title says the gist of it. Found a 71 3/4 truck posi rear end. And was wondering if the GM 4 and/or 5 speed transmissions can be mounted. I mean up to including early 1990s trannys and rear ends.
1971 LeMans 350ci 2Barrel Carb
B. Co 1-22 4ID OIF 2008-09
SPCMarty is offline
post #2 of 14 (permalink) Old 01-12-2012, 08:40 AM
GMC and Chevy trannys are going to mount to the engine with the wrong bolt pattern. You may be able to use an adapter plate. Rear end is going to be from a leaf spring with the truck to a coil spring and 4 link with the GTO, so unless you go with an aftermarket 4 link sub frame and links, I'd say no, they won't work without tons and tons of fabbing. Would be cheaper and easer to just get the parts that fit.
post #3 of 14 (permalink) Old 01-13-2012, 06:54 AM Thread Starter
SPCMarty's Avatar
So much for that idea then, thank you
SPCMarty is offline
post #4 of 14 (permalink) Old 01-13-2012, 11:36 AM
Doesn't mean it can't be done, it's just going to be more difficult. If you want to fit soemthing badly enough, it can usually be dome somehow - it's just a question of how hard and how expensive it's going to be.
If you've got an idea you're passionate about, dont' let that stop you.
post #5 of 14 (permalink) Old 01-13-2012, 04:33 PM
facn8me's Avatar
I took a rear diff out of a 89 GTA and cut all the brackets off of it and welded some spring perches on and stuck it under a v-8 s-10 blazer I used to have. Of course your idea is opposite. You would have a bunch of brackets to line up and weld on. It's possible. Just time and fabrication. As for a 4- speed Depends on the tranny. A m-21 is a m-21 doesn't matter if it's a chevy or pontiac or buick or what ever. As long as you have the correct bell housing they bolt up. Several after market tran's 5-6 speed that would bolt up with the correct pontiac bell housing too. Unfortunatly not all of it is cheap.
https://www.gtoforum.com/signaturepics/sigpic18842_1.gif
1966 Pontiac Lemans Convertible
389 tri power
facn8me is offline
post #6 of 14 (permalink) Old 02-18-2012, 07:15 AM Thread Starter
SPCMarty's Avatar
If I swapped in a newer Chevy 350 motor then I think a GM 5-speed would match up. Or is there a year cut off where Chevy 350s do not fit at all?
SPCMarty is offline
post #7 of 14 (permalink) Old 02-21-2012, 07:45 PM Thread Starter
SPCMarty's Avatar
The Borg warner T5 seems the have the same four bolt pattern as Muncie. The shifter looks to be different however, is there a way to overcome that
SPCMarty is offline
post #8 of 14 (permalink) Old 02-21-2012, 07:47 PM
Quoted: 16 Post(s)
T5 won't last very long behind anything with enough power to drive through Mcdonalds...... And the GM 5 speed is mounted at an angle from centerline of motor (still perpendicular lol)with a specific bellhousing and boltpattern and is really just not strong enough. Why do you think GM only put them behind 305's and not the 350's? I would swap in a Muncie or a t-10 with a factory Pontiac bellhousing and all the linkage if you want a stick. A stickshift behind your 350 Pontiac with some sensible mods would make for a pretty neat little package. Back it up with a 3:55 rear axle and have some fun while you save up for that 400+ inch engine.
post #9 of 14 (permalink) Old 02-21-2012, 08:13 PM Thread Starter
SPCMarty's Avatar
is there much difference between the Muncie M20, M21, and M22 besides the 20 being wide ratio and the 21/22 close ratio?
SPCMarty is offline
post #10 of 14 (permalink) Old 02-21-2012, 09:23 PM
Quoted: 16 Post(s)
All have 1 to 1 fourth gear, on the M21 and M22 the ratios are spread more evenly, the M20 has a larger 3rd to 4th gear spread.
Searching for original part numbers on motor tranny and rear par4n1 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 17 02-05-2010 12:11 PM
Ran over a truck tire...I think Bowdy's GTO 2004-2006 GTO General Discussion 9 01-01-2008 07:55 PM
Truck, SUV oil vs. car oil?? Zebra Engine Discussions 5 12-03-2006 10:50 PM
pontiac tranny to chevy tranny wannagofast 1964-1974 Tempest, Lemans & GTO General Discussion 1 03-27-2006 09:23 AM
