Can't get transmission all the way in - Pontiac GTO Forum
post #1 of 20 (permalink) Old 06-08-2015, 06:54 PM Thread Starter
I read several posts on various websites about installing this Muncie 4 speed into my GTO but still am having problems. A few years ago, I had the transmission rebuilt and re-installed it without a problem. Fast forward to now. I took the transmission out again for weird shifting issues and was told that my clutch was probably worn so I replaced the flywheel, clutch, and this pilot bushing
http://www.summitracing.com/parts/RAM-BU75
I am still about 1" short of the bellhousing. Before I mess something up, is it ok to lightly enlarge the bushing while installed with a dremel on the lowest speed? I assume the problem may be that the shaft isn't going into the bushing all the way? I used the clutch alignment tool and only removed it after installing the bellhousing and just before the transmission. The alignment tool goes into the bushing but very snug. I also tried using two long bolts on the top holes with the heads cut off for alignment.
I'm no mechanic by any means but thought this looked fairly straight forward. I appreciate any and all help. Thanks.
Mikes145 is offline
post #2 of 20 (permalink) Old 06-08-2015, 08:19 PM
Quoted: 404 Post(s)
Pilot bearing looks about right to me. You DO NOT want to use a dremel on it. Pull it out and slide it on the end of the trans input shaft if your feel it is not fitting correctly.
1. Did you match up your old pilot bushing with the new one? It is possible it is not seating correctly. Look in there with a flashlight to make sure it is going into the crankshaft all the way. I did have one that was too large in diameter and set it up on a drill and sanded it down a tad to get it to fit, but it has to be a snug/tight fit so it does not spin in the crank.
2. New flywheel? Which one did you use? a.) The Hays 10.5"-11" dual pattern flywheel, if you used this, is not balanced to match your engine. You may experience a vibration. b.) The Hays flywheel uses the "short" head bolts at the center hub where it bolts to the crank as it is not as deep as the factory flywheel and the larger bolt heads may hit the clutch disc springs. (Ask me how I know a & b )
3. Did you replace the clutch disc and diaphram with the exact same brand/type that came out of your car? Some kits include the throwout bearing which can be wrong for a Pontiac application (another one of my experiences). I've never had any interference problems, so I don't think this should be a problem unless it is not sliding on the collar and hanging up for some reason. I would check that it slides the full length of the collar it rides on. If you install the wrong length throwout bearing, your clutch will not release properly. There is a short, intermediate, and long throwout bearing. (With the trans in position, can you move the clutch fork? Make sure it is not binding for some reason and hanging your trans up.)
4. If you know that the pilot bearing does indeed fit the end of the trans shaft, then I would measure from the pilot bushing (installed in the crankshaft) to the outside edge of the bellhousing and then measure from the shoulder of the input shaft (where the back of your pilot bushing will ride) on the transmission to the front of the trans case. You should have the same measurements. If the measurement you took off the trans is longer than the measurement you got from just the pilot bushing to back edge of the bellhousing -you have a problem, and that has to be that the pilot bushing is not right or seating deep enough into the crank.
5. If everything checks out, sometimes the collar at the front of the trans which your throwout bearing rides on, and centers the trans into the bellhousing, can be a real snug fit and can seemingly cause a problem. It fits into the bellhousing pretty tight, and maybe moreso that it is hotter in the summer and all things expand. You want to make sure it is going in square and level, any angle will add to the problem, as will the weight of the trans if it is hanging. It is best supported with a jack versus doing the "he-man muscle up and in" technique that most of us have done.
You can draw the transmission into the bellhousing using the 4 attaching bolts. BUT, IF DONE WRONG OR YOU FORCEFULLY TIGHTEN THEM, YOU MAY BREAK AN EAR OFF YOUR TRANSMISSION. I have had the same experience where it would not go in that last little bit and used the tightening procedure to draw the trans in that last amount, but I know everything that went in was exactly what I had taken out and everything matched/fit. Never broke an ear off any of my transmissions, but it can happen. Sometimes you can put just a little tension on the bolts and then give it a shake/jiggle while pushing in to seat it that last bit.
In any case, you want to double check everything. Match your parts up and make sure they fit. Hate to say it, but if it isn't American made (and much of it isn't) the fit is not always as it should be, so check everything.
post #3 of 20 (permalink) Old 06-08-2015, 10:55 PM
Did you try having someone step on the clutch while you try to get it in? If your by yourself I've use'd a small come along, hook it on the fork and around the rear axle to pull it in so it will move while your trying to get the tranny in. Probaly not the smartest thing to do it but it works.
JLuger is offline
post #4 of 20 (permalink) Old 06-09-2015, 07:04 AM
rickm's Avatar
Quoted: 5 Post(s)
just the slightest bit of rust or corrosion on the end of the shaft will make the tranny not go in all the way.
rickm is offline
post #5 of 20 (permalink) Old 06-09-2015, 08:59 AM
Quoted: 16 Post(s)
+1 on having someone push in the clutch while you "seat" the transmission in the pilot bearing.
DO NOT force or try to draw the trans in with the bolts, it should go right in once the pedal is pushed in or something is out of line.
post #6 of 20 (permalink) Old 06-10-2015, 10:44 AM
Quoted: 119 Post(s)
What all these guys said. NEVER pull in a trans with the bolts. Have a buddy jump in the car and push the clutch while you stab the trans from under the car. It'll slide right in. BTDT many times! You can also try rotating the mainshaft to engage the clutch plate while you push the trans forward. Sometimes these things go easily, sometimes they like to put of a fight.
post #7 of 20 (permalink) Old 06-10-2015, 05:55 PM
Quoted: 404 Post(s)
Gotta admit, never did the "push the clutch" trick. I also never used the alignment dowel, I had the front input shaft from a Muncie that I used (and still have) that I slid into the pilot bushing and got the clutch disc aligned prior to trans installation. Learned a new trick.
post #8 of 20 (permalink) Old 06-11-2015, 10:18 AM
Quoted: 119 Post(s)
Jim, the actual imput shaft from an old Muncie as an alignment tool will work really well. It's the best way to go. Most people don't have one, though, and the plastic one that comes in the clutch kits isn't a precise fit. The clutch-push trick seems to always work well for us struggling gravel-backers, though!
post #9 of 20 (permalink) Old 06-11-2015, 11:04 AM
Quoted: 16 Post(s)
^ Ahh, gravel driveways are hell when putting in a trans, but they are easier to clean.
I will say I'd rather bench press a Muncie into place over a turbo 400!
post #10 of 20 (permalink) Old 06-11-2015, 02:52 PM
Make sure the tranny is in gear too, if not when you twist it to try to line up the splines the input shaft won't turn like you need it to.
New transmission Robert 69 GTO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 04-01-2012 11:47 PM
transmission help redgtslow Drive train, suspension, alignment and brakes. 3 07-21-2011 08:12 PM
4 L 80 transmission KarLvr 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 11-08-2010 09:32 AM
Transmission ID bkellis1 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 07-13-2009 04:08 PM
Transmission Help Todd6790 Service, Maintenance and Technical Discussion 25 01-04-2005 11:16 AM
