Carrier Swap or Rear assembly swap - Pontiac GTO Forum
post #1 of 7 (permalink) Old 07-16-2013, 11:23 PM Thread Starter
AMT1379's Avatar
My 67 has a 12 bolt donor rear with 4.10:1 r&p gears. I don't take it to the strip so it's a bad fit for me.
Any opinions on what's most cost effective, swap out the carrier and the r&p for a 3 series carrier and and 3.55:1; or try and locate a Poncho 10 bolt 3.36:1 and get it back closer to "stockish"? I priced the carrier swap option through Randy's R&P and I'm looking at near a grand for parts alone. Still trying to find a 10 bolt 3.36:1 (or so) from a similar era car.
Both options I'd be selling the old carrier an 4.10s or selling the full 12-bolt rear assembly drum to drum.
Just for context. Trying to get my car baby home to a new house two states away. I'm in the process of moving and circumstances are forcing me to finally make this call and get the swap done ASAP. In an ideal world I would turn this 15 year driver project car into a fun family weekend cruiser, I don't anticipate ever winning a drag race or car show.
Rumble Rumble Rumble
AMT1379 is offline
post #2 of 7 (permalink) Old 07-17-2013, 05:20 AM
Koppster's Avatar
Koppster is offline
post #3 of 7 (permalink) Old 07-17-2013, 08:21 AM Thread Starter
AMT1379's Avatar
Koppster, thanks for the lead. I thought the 66 rears weren't a good fit for the 67's. I think I remember reading they were slightly shorter? I'm certainly no expert so I could be wrong on that.
AMT1379 is offline
post #4 of 7 (permalink) Old 07-17-2013, 09:09 AM
Quoted: 11 Post(s)
My 67 also had a series 3 12 bolt with 4.10:1 gears which I changed to a 3.42:1 and have been happy with the results. The R&P thru Jegs is a little over $200,
Richmond Gear GM 12-Bolt Ring & Pinion Sets - JEGS
05GTO is offline
post #5 of 7 (permalink) Old 07-17-2013, 10:54 AM Thread Starter
AMT1379's Avatar
I had assumed it had a 4 series, didn't realize the 3 series could also have 4.10s, I've got some more investigating to do.
If I do have the 3 series, I might be able to save a lot.
AMT1379 is offline
post #6 of 7 (permalink) Old 07-17-2013, 03:29 PM
Icefan71's Avatar
I have a 72 Lemans. I just swapped in a 66 Tempest 3.36 rearend. It is shorter than my 72. But its in place with the tires on and I can't tell the difference. There are no clearance issues. The only problem I had was I had to get coil spring retainers and exchange my new 72 springs for 66 springs. The spring pad on the rears are different.
Icefan71 is offline
post #7 of 7 (permalink) Old 07-21-2013, 03:55 PM
Quoted: 119 Post(s)
The '66 and earlier 8.2 rear ends are 1 inch narrower (shorter axle tubes). This will allow more tire clearance, which is a good thing.
Rear Axle Swap 68Temp 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 06-20-2012 12:14 AM
Rear Axle Swap 68GTO4004Spd 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 5 01-26-2012 09:33 PM
Rear end swap GuatoLT1 2004-2006 GTO General Discussion 5 02-06-2011 03:04 PM
Rear end swap?? The intimidator Drive train, suspension, alignment and brakes. 6 02-04-2009 02:05 PM
rear end swap wallacefan 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 12 11-09-2008 04:11 PM
