Centering Body on Frame - Pontiac GTO Forum
post #1 of 15 (permalink) Old 10-31-2014, 12:46 PM Thread Starter
Quoted: 106 Post(s)
I had 4 people in my 67 GTO the other day and the tire was rubbing on the passenger side rear.
I haven't taken a measurement but on the driver's side I can stick my hand between the fender and the tire up to my palm, on the passenger side I can barely get my fingers in there.
The car has no repairs or bondo in either fender is there a way to center the body so I have the same distance on each side?
I thought it was the trailing arms since the bushings were worn and one was slightly bent but after replacing them nothing changed.
Any ideas on how to fix this would be appreciated.
Goat Roper is offline
post #2 of 15 (permalink) Old 10-31-2014, 01:03 PM
Al T's Avatar
I'm not sure what you have for rims but are you sure both have the same offset?
As far as the "centered on the frame" question, you should be able to measure from the outside frame rail at the rear to the quarter panel and then at the cowl to the frame. A comparison of measurements side to side should tell you how the body is sitting.
Good luck.
Al T is offline
post #3 of 15 (permalink) Old 10-31-2014, 01:14 PM Thread Starter
Quoted: 106 Post(s)
Good luck.
Thanks for the input, I will pull the wheels and check the offset but they appear to be a matching set.
I will also take the measurements you suggested and post the results.
post #4 of 15 (permalink) Old 10-31-2014, 02:13 PM Thread Starter
Quoted: 106 Post(s)
Well the measurement is 8 3/4 on the money both sides from frame to fender, the offset the same on the wheels and off of a level on the edge center of fender to the first body line on the top is 1 5/8 both sides so the fender isn't bowed in.
From the tire to inside fender is 5/16 ths on the passenger side, 13/16 ths on the driver side.
It appears that the rear end needs to be shifted over but the car tracks straight and looks good pulling a line down both sides.
Should I shave the inside of the fender?
Looks like 3/16ths should do it going by a straight edge off of the tire.
The tires are new 235 redlines and plane out perfect with a straight edge across both tires side by side.
Both rear springs are new and the measurement is 19 5/8ths on both sides at the top of the jack slots.
post #5 of 15 (permalink) Old 10-31-2014, 02:57 PM
kilkm68's Avatar
I have the exact same problem with my 68. Tires rubbed with passengers in back seat and same clearance difference between left and right side. I'm running 275 /60/15 on Crager 15x8 wheels. I'm considering shaving the lip on the wheel well also.
kilkm68 is offline
post #6 of 15 (permalink) Old 10-31-2014, 03:21 PM Thread Starter
Quoted: 106 Post(s)
Summit has an airbag kit that goes inside the springs on the 68 but it doesn't fit the 67.
http://www.summitracing.com/parts/ai.../gto/year/1968
It would be nice if I could raise it when I have extra weight in the car, I could also use 1" lift blocks but I seldom have 4 people in the car and don't want to change the way the car sits.
It looks like shaving the lip is what I will have to do.
post #7 of 15 (permalink) Old 10-31-2014, 03:54 PM Thread Starter
Quoted: 106 Post(s)
Well after doing a little more research the stock tire size is 225/70-15 and the tires on the car are 235/70-15.
I think this is why they are rubbing with 4 people in the car.
post #8 of 15 (permalink) Old 10-31-2014, 09:18 PM
eeyore's Avatar
Could it be a salvage yard axle with the wrong off set.
eeyore is offline
post #9 of 15 (permalink) Old 10-31-2014, 10:31 PM Thread Starter
Quoted: 106 Post(s)
Maybe that is possible but I had to use kroil and my impact wrench to remove the bolts on the trailing arms, some vintage rust on them and I don't think they have ever been removed.
Does anyone know if there is a number on the rear end I could check to see if this is the original rear end?
Edit: Numbers are on the right rear axle tube near the carrier, I will check these in the AM.
Update: The rear end has code WD which is the 2:93 rear end for this car w/factory air so it is the original rear end that came with the car per the PHS report that came with the car.
The tire barely rubs on the fender and only with 4 people in the car so I will live with it until I need new tires then I will buy the proper 225 tires for the car.
post #10 of 15 (permalink) Old 11-01-2014, 12:41 PM
eeyore's Avatar
If memory serves, it's a coil spring car with a 4 Link and No left to right track bar?
It could be a normal condition. These old cars have lots of history. Could have been slid sideways into a curb and slightly bent all the arms.
I would get it off the ground but with the weight on the wheels and do more eye balling and measuring.
eeyore is offline
Body off frame question mrvandermey 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 12 04-19-2014 07:09 PM
Body off frame question Wmkcchwhite 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 16 07-29-2011 02:33 PM
68-72 A-Body Frame Questions TK69tempest 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 7 04-02-2011 01:51 AM
Body off frame question. Josh.AZ.GTO 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 09-22-2009 06:39 AM
