Clutch bracket 65 GTO - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-18-2017, 10:41 PM Thread Starter
Quoted: 4 Post(s)
Hoping someone might have a picture of the bracket on the frame that the clutch shaft mounts on. I'm doing some restoration and someone has modified the existing bracket with a cutting torch, would like to make it look original.
Thanks for any info
Jim
jedi is offline
post #2 of 3 (permalink) Old 02-19-2017, 03:12 PM
GTOJUNIOR's Avatar
Quoted: 66 Post(s)
This is the only one I could get a clean shot of,
It's on of the chassis of a '66 in the shop but should apply to '65 as well.
Hope it helps.
Name:	Z BAR COUNTER SHAFT BRKT 2.jpg
ID:	87225   Click image for larger version
Name:	Z BAR COUNTER SHAFT BRKT 1.jpg
ID:	87233   Click image for larger version
Name:	Z BAR COUNTER SHAFT BRKT 3.jpg
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 3 (permalink) Old 02-19-2017, 08:57 PM Thread Starter
Quoted: 4 Post(s)
That really helps a lot, sort of did it that way, now just have to round off the top a bit. Frame goes in for blasting and powder coating tomorrow.
Jim
jedi is offline
68 GTO Clutch Return Spring Bracket bgumpper 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 05-01-2016 10:45 PM
1965 clutch linkage bracket Pontiac Tempest Cstm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 03-23-2010 07:46 PM
70 GTO Alternator Bracket ID macgto7004 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 03-01-2008 06:41 PM
