Clutch Burning Smell + Failed Burnout Attempt - Pontiac GTO Forum
post #1 of 9 (permalink) Old 08-25-2018, 06:06 PM Thread Starter
Hi,
I have a 1967 GTO and went out for a 1 hour ride this evening and had a great time. Towards the end of my trip, there is a back road by me where I like to practice hole shots for fun. It is on a slight incline but that has never been a problem before. I rev the motor and dump the clutch only be met with the clutch not grabbing, the motor revving and the car gradually taking off and this awful burning smell. Yikes! Any ideas on what this issue could be? Simple adjustment? New clutch needed? How can I tell? Thanks!
-Tony
TonysGoat is offline
post #2 of 9 (permalink) Old 08-25-2018, 08:57 PM
Quoted: 155 Post(s)
Hmmmm that sounds like you toasted clutch. May have created a hot spot. May be a sign that it is on the way out. May be a sign that the motor is too much for the clutch. Or maybe you just did not launch optimally.
Clutch adjustment is just about where the clutch begins to pick up / clamp, so I don't believe this is your issue.
My guess is the clutch is fine, but not up to the task of holding 400+ ft-lbs of torque.
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #3 of 9 (permalink) Old 08-26-2018, 02:41 PM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
well
from owning several manual transmission GTO's
and GM trucks thru the years... it sounds like the last drive for that clutch and flywheel
it may have gotton a little oil on it or the adjustment was a little tight causing it to slip
once they get that hot they are usually toast..........
bummer
time for a centerforce .....sounds like a 800.00 repair ....
350 for the clutch 375 for a flywheel and lube ......
Scott
BLK69JUDGE is online now
post #4 of 9 (permalink) Old 08-26-2018, 08:49 PM
Quoted: 391 Post(s)
Try adjusting the clutch first, then if no change, its time for a new clutch/pressure plate.
post #5 of 9 (permalink) Old 09-22-2018, 06:10 PM Thread Starter
Hi, I shortened the clutch rod by 3/4 of an inch and what a difference! It is now grabbing again and I am able to smoke the rear tires with ease
The clutch now engages when about 1 inch off the floor from a stand still, before this adjustment it was 2-3 inches before it would grab.
I may be on borrowed time with this clutch / pressure plate / flywheel combo, but for now I am just going to drive it and enjoy it. Thanks all for your suggestions and taking the time to respond.
post #6 of 9 (permalink) Old 09-23-2018, 10:53 PM
Quoted: 155 Post(s)
Can you explain how you did this ? My clutch is starting to slip (I doubt adjusting the pickup point will fix the problem, but I will try)....
Current setup:
4 speed Muncie
post #7 of 9 (permalink) Old 09-25-2018, 07:54 AM
Quoted: 36 Post(s)
You might get lucky and be free of any problems with it. Just keep driving it. Time will tell. Always does.
Nicholas is online now
post #8 of 9 (permalink) Old 09-28-2018, 05:27 PM Thread Starter
Hi cij911 - I put the car front end on jack stands & put a blocks under the rear. I crawled under it and loosened the lock nut on the clutch rod. I then twisted the clutch rod clockwise and which made it shorter. Then I tightened the lock nut. If you want, I can take a few pics and post them, let me know. Your mileage may vary on the adjustment, but for me, for now, it was worth the 10 minutes of effort.
post #9 of 9 (permalink) Old 09-28-2018, 10:14 PM
Quoted: 155 Post(s)
Thanks Tony! So essentially you are just adjusting the pickup point. I'll give it a try, but no idea why it would affect the disc pressure. (My pickup point is rather high, so having it closer to the floor would be preferential to me.) Thanks
Current setup:
4 speed Muncie
Burning smell. blackout goat Service, Maintenance and Technical Discussion 6 01-25-2009 01:03 PM
Burning smell Icarus Service, Maintenance and Technical Discussion 9 04-09-2007 04:20 AM
New 06 Slight Burning Smell gage Service, Maintenance and Technical Discussion 22 03-30-2006 01:05 PM
Burning smell? MACHINE HEAD 2004-2006 GTO General Discussion 8 12-29-2005 09:28 AM
burning smell? tommycheng1728 2004-2006 GTO General Discussion 10 12-07-2005 08:31 PM
