Clutch linkage or starter problem ? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 12-28-2018, 10:28 AM Thread Starter
My clutch linkage is hitting the starter solenoid.
The linkage is from a 1964-67 Chevelle (ebay purchase)
Starter is a late model 1975, that was in a 350 Pontiac from a 1968 Firebird.
Are the earlier starters different ?
Ken
Ken 66gto is offline
post #2 of 7 (permalink) Old 12-28-2018, 10:32 AM Thread Starter
A few pictures
ID:	116993   Click image for larger version
post #3 of 7 (permalink) Old 12-28-2018, 12:58 PM
BLK69JUDGE's Avatar
Quoted: 70 Post(s)
ahhhhhhhhhhh
bummer
fairly sure you need the a body PONTIAC bell crank aka z bar
chevrolet s the starter is on the passenger side ...........
so the design is different ...
As far as I know Everything chevelle is different ... from the pedal swing pin on the chevy pontiac has a bolt thru the pedals ...to the push rod end sizes and shape to the z bar cimentions
fit ?? yes ......kinda .... correct NO
Scott
BLK69JUDGE is online now
post #4 of 7 (permalink) Old 12-29-2018, 06:41 AM Thread Starter
Anyone have an extra z bar ?
Trade for a Chevelle one 😃
Ken
post #5 of 7 (permalink) Old 12-29-2018, 11:50 AM
Quoted: 401 Post(s)
Originally Posted by Ken 66gto View Post
Ken
Ames has them as do most Pontiac parts suppliers. Here is a photo of what you are looking for. https://secure.amesperf.com/qilan/De...A&web_access=Y
post #6 of 7 (permalink) Old 12-29-2018, 04:48 PM
BLK69JUDGE's Avatar
Quoted: 70 Post(s)
youlle need the z bar
the push rod thru the firewall
the adjuster rod all for the pontiac..
then
you may need to pull the clutch pedal to modify the
the push rod hole to fit from chevy to pontiac....the arm off the clutch pedal.. its hole ..
think about where the rod meets the z bar now .... its got to move over an inch on the pivot tube
from block to frame
try and use the same push rod thru fire wall and all the angles will be jacked out of whack...
sell what you have to a chevy guy and buy all the right stuff
pedals with circles stamped into em and not horizontal lines.... and a pivot bolt not a pin
post #7 of 7 (permalink) Old 12-30-2018, 09:00 AM Thread Starter
I saw that picture before I made the ebay purchase. The one I bought looks very similar.
Going to return, good thing I cleaned it for them.
http://https://www.ebay.com/itm/64-6...72.m2749.l2649
Clutch Linkage hayes68gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 07-25-2019 08:19 PM
clutch linkage repair Chris-Austria 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 6 02-07-2014 10:01 PM
67 GTO Clutch Linkage Adjustment Hub0351 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 12-25-2012 09:36 PM
Broke clutch pedal plasctic linkage... Anyone Help? Apache443 2004-2006 GTO General Discussion 0 07-11-2012 06:46 PM
1965 clutch linkage bracket Pontiac Tempest Cstm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 03-23-2010 08:46 PM
