Code on front frame rail? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 12-23-2012, 08:27 PM Thread Starter
leeklm's Avatar
More curious than anything... I found the number 6-D28-C40 on the inside of the right front frame rail on my 66 (in-between the engine cross member and bumper). Anyone know what this code means?
leeklm is offline
post #2 of 5 (permalink) Old 12-24-2012, 10:10 AM
jmt455's Avatar
I'm guessing that the 6-D28 is the manufacturing date code for April 28th, 1966.
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #3 of 5 (permalink) Old 12-24-2012, 11:42 AM
That makes sense at least. The vin ought to be on top of the frame rail, driver's side rear behind the wheels. At least that's where it is on my 69.
post #4 of 5 (permalink) Old 12-24-2012, 03:45 PM
frame
My number is in the same spot as Bears'- crisp and clean. ('66 Lemans convertible)
gjones is offline
post #5 of 5 (permalink) Old 12-24-2012, 06:48 PM Thread Starter
leeklm's Avatar
Did some googling and have not found anything on the front rail number. Car was built in March of 66, or at least when it was ordered, so I suppose April 66 could be accurate. There has been some cobbled up welding at one time in the past 40 years around the upper control arm, which I am fixing now. based on some damage to the original hood, looks like it had some front-end damage, and then tweaked on the frame rack (which likely explains the cracks behind the lower control arm mounts). The front frame & engine cradle were orange, which I assume was either "chevy orange" from a replaced clip, or someone went with a "tiger orange" theme at some point. The front body mounts felt like they had been in for 46 years as I twisted one off replacing them, so doubt it every had a new clip.
Have a Merry Christmas!
leeklm is offline
Strange '65/66 frame code. Markd15668 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 12 11-06-2011 05:01 PM
Help identifying front frame section Too Many Projects 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 02-15-2009 11:28 PM
front license plate frame tamerlane57 Exterior Discussions 2 08-23-2006 04:34 PM
04 GTO Frame Rail Sectioning mjrock62 Service, Maintenance and Technical Discussion 0 10-26-2004 01:04 PM
