Converting to His and Hers - Pontiac GTO Forum
 2Likes
  • 1 Post By Ebartone
  • 1 Post By PontiacJim
post #1 of 7 (permalink) Old 09-09-2019, 03:52 PM Thread Starter
Ebartone's Avatar
Hello,
My 1968 GTO "came with" I'm pretty sure a 1969 TH400, and the shifter is now just a standard shifter. Is it possible to convert this to a His and Hers; is it just a matter of the proper set up?
Thanks!
Ebartone is online now
post #2 of 7 (permalink) Old 09-09-2019, 05:57 PM
Quoted: 391 Post(s)
Originally Posted by Ebartone View Post
Hello,
Thanks!
The His/Hers shifter can be added. However, unless you have the correctly modified TH-400 that came with the His/Hers, you won't gain anything other than look. The factory transmission allowed manual shift control of 1st & 2nd gear, thus the right shift selection. Put it in Drive and the trans would shift automatically. The shifting between gears is firmer and harder. The '68 GTO I once owned, non-posi, had the His/Hers and I could chirp the tires on a 1st to 2nd gear blast.
The 1969 GTO came with Pontiac's version of the His/Hers, but did not look like the more desirable 1967-68 unit.
You can add an aftermarket shift kit, something like Trans-Go, that will modify your TH-400 to have the manual 1st & 2nd gear control as well as the automatic shifting of the gears when put in Drive.
To see what is involved in adding the His/Hers, your 1968 Pontiac Service Manual will show you what is needed and how to adjust it.
post #3 of 7 (permalink) Old 09-09-2019, 06:15 PM Thread Starter
Ebartone's Avatar
Thanks Jim! As always I appreciate your reply. I’ve been meaning to run around and write down all of my casting numbers, trans number, etc. I suspect that will help me know what boat I’m actually in. Thanks!
PontiacJim likes this.
post #4 of 7 (permalink) Old 09-09-2019, 11:18 PM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
hmmmm
I thought every 68 GTO w the th400 came factory with a one year 68 HURST dual gate shifter....
like every Muncie 68 GTO had a HURST Manual shifter ....
BLK69JUDGE is offline
post #5 of 7 (permalink) Old 09-10-2019, 10:08 AM Thread Starter
Ebartone's Avatar
Originally Posted by BLK69JUDGE View Post
hmmmm
I thought that as well, however I'm pretty sure this is not the original trans/shifter. When I find numbers I'll share them....
post #6 of 7 (permalink) Old 09-10-2019, 04:44 PM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
pictures work also
post #7 of 7 (permalink) Old 09-10-2019, 07:37 PM
Quoted: 391 Post(s)
hmmmm
What, no column shifted TH-400's in a GTO?
geeteeohguy likes this.
