Difference between '65 GTO console and non-console shifters - Pontiac GTO Forum
post #1 of 9 (permalink) Old 10-04-2018, 03:58 PM Thread Starter
Can anyone tell me what the difference is between the Hurst shifter used with a console, vs. one used without a console? I am restoring a '65 GTO, converting from automatic to Muncie 4-speed. I am putting in a console and will need a shifter that is compatible with the console. Any info would be a great help. thanks!
2ocnorb is offline
post #2 of 9 (permalink) Old 10-05-2018, 04:31 AM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
The only STICK variations I'm aware of relate to seats. Bench Vs Bucket.
The difference for Console cars Versus Non-Console is the Boot and Retainer.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 9 (permalink) Old 10-10-2018, 04:43 PM
Quoted: 117 Post(s)
This^^^. A correct '65 GTO shifter is a fairly straight and tall unit, and is designed (and used) for both applications. Only a rare bench car with no console has a different more aggressively curved shifter.
post #4 of 9 (permalink) Old 02-06-2019, 10:52 AM
Quoted: 9 Post(s)
Since we're on the subject, my '65 4speed built w/o a console. I'm looking to add a console and see on ebay two types of the GM shifter tunnel pan (that screws to the hump). Pictures are attached of the two styles. The one in my car is the type with the smaller round hole. If i'm going console, do i need the other style that has more opening room, or does it not make a difference? Thanks for any input.
ID:	117463   Click image for larger version
wishihaditback is offline
post #5 of 9 (permalink) Old 02-06-2019, 04:14 PM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
65-66 With console this is the tunnel you need;
https://www.ebay.com/i/132675284240?chn=ps
ID:	117471   Click image for larger version
ID:	117473   Click image for larger version
Name:	1995 INTERIOR SHOT.jpg
post #6 of 9 (permalink) Old 02-06-2019, 04:40 PM
Quoted: 9 Post(s)
Thanks for the pics and the ebay link. I'm guessing then that the tunnel pictured is the same for a non-console car. Thanks again.
post #7 of 9 (permalink) Old 04-17-2019, 10:38 AM
Quoted: 117 Post(s)
The shifter porch on the right with the small hole is a Pontiac-type part. The one with the big hole on the right is not part of any Pontiac I've ever seen. Not even close.
post #8 of 9 (permalink) Old 04-17-2019, 04:05 PM
Quoted: 9 Post(s)
Thanks for your input. I kinda figured the round hole might be the correct one. The other oblong one was on the ebay and stated it also was for a '65 goat. Always best to ask! Thanks again.
post #9 of 9 (permalink) Old 04-24-2019, 10:32 PM
varmit86's Avatar
If anyone is interested i have a muncie 4 tranmission low mile never been apart with bell housing, clutch and pressure plate, shifter all of it out of my early 66 GTO. Pricey but great virgin parts with correct numbers.
varmit86 is offline
difference between 1970 GTO and 1971 Lemans kickn59 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 12-24-2014 08:01 AM
Whats the difference in the doors between Tempest and GTO torpedo51 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 3 01-19-2014 11:16 AM
Difference between '64 GTO and '68 Firebird grille grzessk The Lounge 0 02-17-2013 12:02 PM
What's the difference between the GTO and the judge psilentchild 1964-1974 Tempest, Lemans & GTO General Discussion 15 10-05-2012 02:28 PM
Actual differences between and RA block and non RA block DrBoeing 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-26-2010 12:07 PM
