Drive Shaft Spins while in Neutral - 1967 GTO 4SP - Pontiac GTO Forum
 1Likes
  • 1 Post By denrael
post #1 of 3 (permalink) Old 07-30-2018, 05:46 AM Thread Starter
Hello,
I have a 1967 GTO, 400, 4SP with an after market Muncie M22 in it. It is currently up on my 2 post lift with both rear tires off as I debug some rear end noise. While it was on the lift, I started it up the other day and noticed that while in neutral, the drive shaft was spinning as were the rear axles. Does this sound right? I thought that when you were in neutral, none of the drive train should be engaged.
Is this a clutch rod adjustment? If so, do I make it longer or shorter?
TonysGoat is offline
post #2 of 3 (permalink) Old 07-30-2018, 06:27 AM
denrael's Avatar
Quoted: 9 Post(s)
Definitely NOT a clutch issue... unless depressed by the driver, the clutch is fully engaged whether the gearbox is in neutral or not. In any case, it's not unusual for the driveshaft to turn while in neutral. A slight tap of the brake or tug on the e-brake would stop the freewheeling, which is more likely to happen while the gearbox lube is still "cold"
PontiacJim likes this.
denrael is offline
post #3 of 3 (permalink) Old 07-30-2018, 06:31 AM Thread Starter
Great, thank-you for your help!
Ignition key loose and spins Destro23 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-04-2016 09:58 PM
Bearing race spins, where to buy hub? we9v 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 8 04-06-2015 03:54 PM
Steering Wheel Spins Freely MLWGTO 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 15 01-31-2015 01:29 AM
