Engine / Transmission query - Pontiac GTO Forum
post #1 of 3 (permalink) Old 06-30-2013, 01:06 PM Thread Starter
I've been looking around Ebay for a 400 to put in my project. Some of them mention whether they were linked to a manual or an automatic. Does it really make a difference? I thought if you were running an automatic you used a torque converter and if you were using a clutch you just intall the proper flywheel. Your thoughts?
HaloPlayer is offline
post #2 of 3 (permalink) Old 06-30-2013, 06:33 PM
jmt455's Avatar
If you're restoring a car and looking for correct block codes, it matters.
If it's not a "matching" question, you have a lot of flexibility!
If you're installing an automatic, replace the flywheel with the proper flexplate.
If you're running a manual trans, verify that the crank has been drilled to accept the pilot bushing.
Most Pontiac cranks have a stepped hole to accept the pilot bearing/bushing.
Also; if you get a manual trans engine, make sure the old pilot bushing has been removed before you re-assemble your engine.
You want to avoid this issue:https://www.gtoforum.com/f50/pilot-be...k-crank-25621/
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #3 of 3 (permalink) Old 06-30-2013, 08:34 PM Thread Starter
Ya, I can't afford 'numbers matching' ;-)
Just checking as I know little to nothing about Pontiac engines and was puzzled by the 'automatic' comment.
Thanks for the response!
Engine and Transmission mount help mysons69 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 6 06-12-2013 04:48 PM
1965 GTO Engine, Transmission, Diff Codes propuckstopper 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 9 09-06-2012 03:52 PM
1967 GTO Engine and Transmission eng4st8 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 08-29-2009 11:40 AM
