flex plate mounting - Pontiac GTO Forum
post #1 of 3 (permalink) Old 05-26-2014, 05:26 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
flex plate mounting
The machine shop was able to get my flex plate off the crankshaft, someone welded (or ?) one of the bolts.
I see the one piece where the bolts go into, the second piece goes between the crank and plate?
thanks as always
Tk
Name:	bolts wont come off.jpg
Topkat is offline
post #2 of 3 (permalink) Old 05-28-2014, 09:00 AM
allpawl66's Avatar
I have the plate & the longer bolts for use with that reinforcing ring if needed . Send pm with email if needed .
allpawl66 is offline
post #3 of 3 (permalink) Old 05-28-2014, 10:02 AM
Quoted: 119 Post(s)
The flexplate goes directly to the crank, the bolt ring goes on the trans side of the plate.
Driveshaft Flex Disc (04-06 GTO) KamShaft Drive train, suspension, alignment and brakes. 0 02-04-2013 05:15 PM
Hyper Flex Suspension Bushing Set Robertr2000 Drive train, suspension, alignment and brakes. 9 04-27-2006 01:35 AM
