Frame painted - Pontiac GTO Forum
post #1 of 6 (permalink) Old 02-18-2017, 02:42 PM Thread Starter
Wendt69's Avatar
Quoted: 5 Post(s)
Frame painted
So my simple engine rebuild has turned into a body off resto.
I painted the frame with Por 15 chassis black. Turned out great but I would never use a brush to paint the frame again, a spray finish would be quicker and cover the hard to get spots easier.
ID:	87145   Click image for larger version
ID:	87153   Click image for larger version
ID:	87161   Click image for larger version
ID:	87169   Click image for larger version
Wendt69 is offline
post #2 of 6 (permalink) Old 02-18-2017, 02:45 PM Thread Starter
Wendt69's Avatar
Quoted: 5 Post(s)
A few more pics
ID:	87185   Click image for larger version
ID:	87193   Click image for larger version
Wendt69 is offline
post #3 of 6 (permalink) Old 02-18-2017, 05:08 PM
Quoted: 391 Post(s)
I used the Por-15. I also used the Eastwood paint that you spray inside the frame with the extension tube to get inside to coat the internal areas.
PontiacJim is online now
post #4 of 6 (permalink) Old 02-19-2017, 09:40 AM
stich's Avatar
I've got my frame stripped down of all parts and was either going to have it blasted and powder coated or do the POR 15 routine. Pro's and Con's of each? Price IS an issue and no it's NOT a #'s matching car so I don't care about originality. Also, if POR 15, exactly how much do you think I need for just the frame? Not including rear end or suspension.
stich is offline
post #5 of 6 (permalink) Old 02-19-2017, 09:51 AM Thread Starter
Wendt69's Avatar
Quoted: 5 Post(s)
Hey stitch, I used 3 1/2 quarts for my frame and all suspension parts. My first coat was light followed by a heavy 2nd coat. I really liked the lay and spread (ha ha) of the por15, nice to work with. I would have 2 qaurts on hand for just the frame and if you don't dip into the 2nd just return the can. Hope this helps.
Wendt69 is offline
post #6 of 6 (permalink) Old 02-19-2017, 03:35 PM
Quoted: 391 Post(s)
I would have it blasted and then do the POR-15, that is what I did with my frame. I purchased a small 40 lb blaster from Harbor Freight and did it myself. Nasty & dirty and time consuming, but it worked for me.
I also used the POR-15 top coat over the rust protector. Make sure the POR-15 rust protector is thoroughly dried, like give it a couple weeks, or the top coat will soften the undercoat and cause it to crack/crinkle and even lift a little should you decide to use it.
Got it painted AlanSr Exterior Discussions 8 07-05-2013 03:23 PM
Fasteners Painted or not timmyg 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 02-02-2013 02:07 PM
Frame Question (Boxing frame+) Fred007 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 20 12-13-2010 11:38 AM
Another painted rear UF GaTOr Exterior Discussions 20 05-30-2007 05:10 PM
I need it PAINTED GTO6 2004-2006 GTO General Discussion 3 02-07-2007 08:19 PM
