frame repair - Pontiac GTO Forum
post #1 of 13 (permalink) Old 02-12-2012, 12:11 PM Thread Starter
Quoted: 4 Post(s)
frame repair
I have a 1967 Lemans convertible with questionable rust along the rails. I am considering incapsulating the entire rail section from the back to front with 1/8th inch steel plating and wanted to get some feedback from someone who has done this or may have a better reccommendation.
RM9700 is offline
post #2 of 13 (permalink) Old 02-13-2012, 09:25 AM
How much rust 'we talkin' bout Willis? -- and where is it?
If it's just surface rust and hasn't really affected the strength or integrity of the frame, then blast/sand/wire-wheel it off and protect with some sort of coating.
If it's making you question the strength/rigidity of the frame, then depending on how bad it is, it needs to be cut out and have new steel welded in by a skilled welder, or the whole frame needs to be replaced. Running a car with a compromised frame is not something you want to do.
post #3 of 13 (permalink) Old 02-15-2012, 08:45 PM
.......they usually rot out just in front of the rear wheels. You may need to lift the body to make a proper repair....where is the rust?? Pics?? Eric
Eric Animal is offline
post #4 of 13 (permalink) Old 02-16-2012, 07:46 PM Thread Starter
Quoted: 4 Post(s)
Frame Repair
The picture's posted are of the worst section's of the frame.
I do have a good freind that is a union welder.
ID:	13982   Click image for larger version
ID:	13983   Click image for larger version
ID:	13984   Click image for larger version
RM9700 is offline
post #5 of 13 (permalink) Old 02-16-2012, 09:16 PM
Quoted: 11 Post(s)
I would recommend acid dipping the entire frame before you start repairing the rusted areas. You may find the frame is not salvageable. If indeed the frame can be saved then use something like por15 inside the boxed area to prevent future problems.
Here is a company a couple hours north of you in Brampton, On;
http://www.technostrip.com
05GTO is online now
post #6 of 13 (permalink) Old 02-17-2012, 06:48 PM
crustysack's Avatar
A "better" recommendation would be to buy a solid frame, that one can be repaired but it looks like A LOT of work. I would not box around that frame with 1/8 steel, that will not fix it properly. If you want to keep that frame for the # you need to get a donor frame and weld in the sections that are garbage, if you dont care about the frame # just try and find a solid one- it will save you time and $$ in the long run
crustysack is offline
post #7 of 13 (permalink) Old 02-18-2012, 03:06 AM
69Goatee's Avatar
WOW! I looked at the pix, and if it were me I'd get a new frame. If it was under a hardtop I'd say weld away. Converts require a boxed, strong frame or they would fold in half. If you were to acid dip it, I think you would have next to nothing left. Station wagons and El Caminos used the same type of boxed frame. I'm not sure if they would be a bolt in without mods, but it would be worth checking out. My $0.02!
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
RESTORATION IN 1980...
NIN
69Goatee is offline
post #8 of 13 (permalink) Old 02-18-2012, 09:41 AM
Gotta agree with the acid dipping...and/or blasting. That frame is "pretty bad"....I had a 66 vert that did the same thing. On the subject of welding....before you weld, you need to FABRICATE the part.....Personally I'd look for a good chassis and do a swap.... There is a guy named "Boorher, or Borheer...who blasts and powdeccoats frames....also Nitemare Performance in Conneticuit sells restored frames....hunt around. Eric
post #9 of 13 (permalink) Old 02-18-2012, 09:51 AM
Here is an E-gay item # 280827110079 it is for a chassis, fully restored with all rolling parts, including a rear end brakes, exhaust, front end.....it is priced too high, it is probably worth 1/2 the asking price though....do the math. Good luck!!! Eric
post #10 of 13 (permalink) Old 02-18-2012, 12:21 PM
It can be done. Here is the front pass. side corner from my '64 Tempest. It takes time, effort and good welding skills. But it really depends upon how the frame is over-all. Mine had this one really bad corner but most of the rest of it is fine.
Phil
64phil is offline
Frame Question (Boxing frame+) Fred007 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 20 12-13-2010 12:38 PM
Frame repair question/help Fred007 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 9 07-10-2009 09:03 AM
Frame Repair - 1964 Tempest 64phil 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 04-16-2009 10:33 PM
frame repair? ss1885 2004-2006 GTO General Discussion 1 01-24-2007 09:48 AM
Repair Log Tom Rice Service, Maintenance and Technical Discussion 4 02-18-2005 09:55 PM
