Frame Rot on 64 GTO - Pontiac GTO Forum
post #1 of 12 (permalink) Old 09-11-2014, 09:19 PM Thread Starter
tguggino's Avatar
Frame Rot on 64 GTO
Is frame rot on a 1964 GTO convertible 4 speed, tripower the "kiss of death?
tguggino is offline
post #2 of 12 (permalink) Old 09-12-2014, 07:25 AM
Anything can be fixed, for enough money.
How much damage are we talking? Where is it? Usually, by the time frame corrodes, the sheet metal is in such bad shape the car is worthless.
ibarbuckle is offline
post #3 of 12 (permalink) Old 09-12-2014, 08:03 AM
67 Basket Case Restorer
Too Many Projects's Avatar
More info would be helpful but if it is considerable and the body is decent, find a frame in a dry area of the country and replace it.
I drove from MN to OK for a clean frame for my '67...
Everyone's level of what is the kiss of death is different. I will save the roof and most of the original firewall on my basket case...most everything else is replacement parts whether new repro or used donor.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #4 of 12 (permalink) Old 09-12-2014, 08:15 AM
Heh. Bought the VIN? I've learned my lesson. Spend more upfront...
post #5 of 12 (permalink) Old 09-12-2014, 09:51 AM Thread Starter
tguggino's Avatar
the car is a 4 speed, tri power with a 76xw block. (wrong per manifest correct for year and options) It drives and the body top and interier are intact and good condition. Nice rims and all parts are there. The frame is rotted in the common areas. (behind front wheels and in front of rear). Body mounts are rotted or missing is a few spots. besides the frame, car is condition 2+.
tguggino is offline
post #6 of 12 (permalink) Old 09-12-2014, 09:55 AM
post #7 of 12 (permalink) Old 09-12-2014, 11:51 AM
The extent of rust damage in the link above is severe. IF yours is that bad, I strongly recommend replacing it. That much damage can be cut out and new pieces fabricated BUT, the cost will exceed a replacement frame. I have repaired frames nearly that bad at a restoration shop I worked at, but the bare frame needs to be locked down on a frame rack holding it straight, square and level. If the repair is done on jack stands, it will look like a pretzel when done and may not be straightenable on a rack afterwards.
Yes, convertible frames are harder to find and more expensive but if originality isn't important, you can use a sedan/coupe frame and box the center section yourself. That would still be far less work than a major rebuild. Again, if you do major welding on any frame, have it locked down. I've seen good frames reduced to scrap from shrinking and warping during the welding process.
Good Luck...
Mitch
1962 Impala SS
1938 Chev coupe
post #8 of 12 (permalink) Old 09-12-2014, 02:28 PM Thread Starter
tguggino's Avatar
Thanks all.
I found a place that has a new frame, blasted & coated, for $2500.
Is that a good price?
tguggino is offline
post #9 of 12 (permalink) Old 09-12-2014, 05:45 PM
Thanks all.
I wouldn't call it a good price but probably in the ballpark. Powdercoating alone can run 6 hundred. Make sure it's for a GTO and not a Chevelle. The Chevelle frame is shorter.
Mitch
1962 Impala SS
1938 Chev coupe
post #10 of 12 (permalink) Old 09-12-2014, 09:41 PM Thread Starter
tguggino's Avatar
Thanks. How can I be sure it is from a Gto ?
tguggino is offline
rear window rot Logchain 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 9 01-21-2012 11:15 AM
Rear Window area rot tspring 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 13 12-04-2011 07:09 PM
64 rear window channel rot 64tempest 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 08-30-2009 03:03 PM
69 convertible cowl rot DrBoeing 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 8 05-11-2009 10:27 PM
Dry Rot - YIKES bg2m8o The Lounge 4 11-09-2006 12:15 AM
