frame swap - Pontiac GTO Forum
post #1 of 6 (permalink) Old 10-08-2013, 09:39 AM Thread Starter
frame swap
I have a mint 1964 tempest 4-door frame and want to put it under a 1966 gto all body mounts seem to be located correct i believe I have read all threads some say it will be the same some say its a different frame needs modification please help THANKS MIKE
mikey9743 is offline
post #2 of 6 (permalink) Old 10-08-2013, 05:38 PM
rickm's Avatar
Quoted: 5 Post(s)
im just curious, whats wrong with the '66 gto frame?
rickm is offline
post #3 of 6 (permalink) Old 10-08-2013, 11:21 PM Thread Starter
It came from Minn. it is rusting around front bumper brackets and on frame rails I if I did not have this frame I would leave it alone
post #4 of 6 (permalink) Old 10-09-2013, 01:10 PM
chuckha62's Avatar
Quoted: 18 Post(s)
As I understand it, the frame rails and front section are the same, but the frame area that supports the trunk is shorter on the '64-'65 than on the '66-'67. Others may chime in with more info.
chuckha62 is offline
post #5 of 6 (permalink) Old 10-11-2013, 03:40 PM
Quoted: 119 Post(s)
Doing some more digging, it seems that the 4 door frame will indeed work. There are some minor differences in tail length and there are also differences in body mount locations....but this can be fabricated to work out. You need to find someone who has a bare 2 door frame to post photos and take measurements so you can compare to your 4 door frame. That's what I'd do.
post #6 of 6 (permalink) Old 10-12-2013, 07:55 AM
rickm's Avatar
Quoted: 5 Post(s)
ive never done it, but I know the job itself of swapping frames could be quite overwhelming. I would want to do the job with a replacement frame that fits correctly.
rickm is offline
Carrier Swap or Rear assembly swap AMT1379 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 07-21-2013 03:55 PM
T-56 swap Indecision 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 13 02-18-2011 07:53 PM
69 gto frame swap pontiacman63383 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 01-08-2011 09:24 PM
Frame Question (Boxing frame+) Fred007 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 20 12-13-2010 12:38 PM
frame swap question pontiacman63383 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 08-09-2010 03:03 PM
