Gear Venders - Pontiac GTO Forum
post #1 of 2 (permalink) Old 06-20-2016, 08:23 PM Thread Starter
gtoearl's Avatar
Quoted: 22 Post(s)
Gear Venders
Thinking of putting a Gear venders overdrive on my T-400..... Any ideas? Either that or a 200r trany.... Thinking I need another gear for freeway driving... putting out 3000rpm at about 69-70 mph. with a 3:23 rear end...
gtoearl is offline
post #2 of 2 (permalink) Old 06-21-2016, 08:53 AM
1968gto421's Avatar
Quoted: 72 Post(s)
My understanding is that the Gear Vendors would give your TH4000 a total of six forward speeds while the 200R4 would give you only four. With GV, you could keep your current convertor, shifter, etc., while with 200R4 you would need new convertor, etc., and you'd have the feared kickdown cable problem...one wrong adjustment, etc. will lower trans pressures and tranny "meltdown". The 200R4 might be cheaper but a built up one for Pontiac torque could easily exceed the Gear Vendors' expense and the GV does have a rep for handling big power easily.
I guess it's a matter of listing all the pluses and minuses of each and deciding which trade off you can best manage, technically and financially.
Good Luck!
1968gto421 is online now
gear ratio 65gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 10-15-2013 09:53 AM
Speedometer Drive Gear and Driven GEAR timmyg 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-05-2012 03:48 PM
spider gear??? the65gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 03-24-2012 07:59 PM
gear oil? AlanSr Service, Maintenance and Technical Discussion 9 07-02-2009 07:05 AM
Not Going into Gear?! 05LS2FAST 2004-2006 GTO General Discussion 6 09-15-2008 08:33 PM
