GM 8.5 Diff Swap - Pontiac GTO Forum
post #1 of 1 (permalink) Old 12-11-2018, 12:32 PM Thread Starter
69 242 GTO's Avatar
GM 8.5 Diff Swap
I have a 69 GTO with a 8.2 Limited Slip and I have a 8.5 Limited Slip from a 1985 Olds 442 with 3.73 gears and the 200 R4 overdrive trans as well.
Has anyone put a 80's 8.5 in their older Pontiac.
It looks like the overall width dimension on the 8.5 are 3" shorter and the shock holes are 2" less.
Coil spring location is the same but the lower control arms are angled in instead of perpendicular to axle.
Thanks for any help you can provide.
Enjoy What You Have!
Drive It Like You Stole It!
69 242 GTO is offline
Diff Swap Question 67 G T O 1964-1974 Tempest, Lemans & GTO General Discussion 1 06-18-2015 10:24 AM
10 bolt diff gear swap chemnick 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 14 04-07-2014 08:35 PM
question about new gm diff oil 75w-90..... pctek Drive train, suspension, alignment and brakes. 0 10-27-2011 02:01 PM
GM Diff Fluid YellO5LS2 Service, Maintenance and Technical Discussion 2 10-18-2011 08:45 PM
04 diff/05 diff banshee 2004-2006 GTO General Discussion 8 08-23-2007 09:26 PM
