GTO Rear End Identification help???? - Pontiac GTO Forum
post #1 of 15 (permalink) Old 03-13-2014, 06:31 PM Thread Starter
Hi All:
Need help figuring out what I have for a rear end. CN4 is on the lower pumpkin and its a 10 bolt. this is on a 1968 GTO.
Thanks for any help.
Tom
FireFox3434 is offline
post #2 of 15 (permalink) Old 03-14-2014, 02:11 PM
68GTO4004Spd's Avatar
Well if it looks like this, then it's a BOP rear end. To identify, look on the axle tube to the right of the pumpkin, should be about 6" to 12" away 2 letters about 1/2" tall and will be something like ZH. Here's a link to the codes.
http://www.wallaceracing.com/axledata2.htm
68GTO4004Spd is offline
post #3 of 15 (permalink) Old 03-14-2014, 10:05 PM Thread Starter
1968 gto rear end help identification
What is a BOP?
post #4 of 15 (permalink) Old 03-14-2014, 10:17 PM
Originally Posted by FireFox3434 View Post
What is a BOP?
Buick olds pontiac
68GTO_MAN is offline
post #5 of 15 (permalink) Old 03-15-2014, 12:26 AM Thread Starter
Hi here are some pics of rear
ID:	35953   Click image for larger version
ID:	35961   Click image for larger version
ID:	35969   Click image for larger version
post #6 of 15 (permalink) Old 03-15-2014, 11:55 AM
Quoted: 404 Post(s)
Pontiac did not add the rear anti-roll bar until the 1970 model. You have a 1968, so either yours has been added on to the original rear, or the rear end has been swapped to include the sway bar set-up.
68GTO4004sp provided the link you need to identify a Pontiac rear. Find the axle code on the axle tube as noted in the article. The numbers you provided may simply be part numbers or even foundry numbers. Get a copy of your car's build sheet from PHS services which will help identify the original rear end as well as all other codes, parts & options.
post #7 of 15 (permalink) Old 03-15-2014, 02:29 PM Thread Starter
I have the PHS documentation.
post #8 of 15 (permalink) Old 03-15-2014, 02:31 PM Thread Starter
Found GAC 035 2 on one tube in front . If your looking from back of car its on the right in front tube.
post #9 of 15 (permalink) Old 03-17-2014, 06:21 PM
Quoted: 404 Post(s)
Using the forementioned Wallace Rear End Codes provided earlier, it looks like G=Detroit Gear&Axle, AC=1970 Grand Prix, non-posi, 2.78 axle ration. Assume the 03=March and 5 may be 5th day, 2=night shift. Grand Prix's probably had the rear sway bar in 1970.
How does that match with your PHS documents as being the original?
post #10 of 15 (permalink) Old 03-18-2014, 07:08 AM Thread Starter
Thanks Jim now I get how to decode. It didn't match that's why I needed to know what it was.
64 GTO rear end khinton 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 03-24-2012 11:24 AM
Lowering the rear end of a 69 GTO...need help.... Eshack80 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 9 11-22-2010 09:33 AM
Rear axle identification??? ylwgto 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 11-06-2009 09:40 PM
Rear end identification help Jstreet 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 5 04-06-2009 10:17 PM
67 GTO no rear end GTO_KID 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 05-10-2008 01:58 PM
